Losi XXX-S
#9706
Re: Turnbuckles
Originally posted by NVisible
I really dislike adjusting my turnbuckles on my xxx-s. Seems when i try to adjust they always pop out, or i have to use needle nose pliers on one end as i try to adjust them, just a pain in the arse. Im using the ones that came with the RTR kit, would a lunsford set with the rpm ends help this at all? maybe im doing something wrong. I even put lube on them like it said in Drakes article in RC Nitro, but same thing
#9707
Stripped Threads on chassis
Does anyone know how to fix stripped theads on the graphite chassis. I have stripped 2 of the 3 screws on the gear cover and 1 screw on the front diff cover.
#9708
you can either rethread using ca glue or get longer bottom cover screws. i'll try to find the exact screw measurements you'll need.
#9709
Thank you. I will try the CA glue
#9710
2-56x1/4"
#9711
R/C Tech Elite Member
Originally posted by xxxkat
On removing every other tooth on the belt are you doing this on the black belt also ? And how is this belt "trick" holding up in mod,I run a 10x2 most of the time and dont really like changing belts..
#9712
what changes should i make on todd hodge's snowbird's setup for a tight track? i was thinking normal wheelbase and less front caster.
Are the ae hexes really worth it? my hexes always seem to come out with the wheel, so they must be worn, but the price on the ae hexes .
on a side note, i'm really bummed that my local track is closing for the summer. i only got to go there 5 times . now my xxx-s has to go into storage after next weekend .
#9713
Originally posted by racer-oZ
XXX-S Bill, how long have you been waxing your turbuckle? couldn't resist that one!
racer-oZ
racer-oZ
#9714
Originally posted by Cardboard
how many degrees of anti-dive do the low-roll pivot blocks add?
#9715
#9716
...Are the ae hexes really worth it? ...
E
#9717
sometimes when you use 28mm tires they rub and the AE hexes are a bit thicker which is enough to help with the rubbing..
clint
clint
#9719
the use of the ae hexes or other aftermarket hexes were not so much used for clearance with rubbing as they were to compensate for the offset on the older style trc wheels to get the regular track width. the new trc 28mm wheels have the regular offset so you can use the stock hexes.
