Hot Bodies TCX
Old 10-14-2010, 01:11 PM
  #1111
steveonamission's Avatar
Originally Posted by markrobinson
I have just broken a front drive shaft and currently there are no spares in the UK. I've heard that the TOP Photon one's will fit.
Can anyone confirm this?
No they do not, pin diameter is too small so you have too much play in the spool cup..
I cant confirm this, but im thinking for the time being you may be able to fit Tamiyas TA05 or JAAD racing steel spool cups to the tcx spool, then you will be able to use tamiyas 46mm steel driveshafts...
Im yet to break anything yet, done it now saying that havent i
Steve Fuller.
steveonamission is offline
Old 10-14-2010, 02:02 PM
  #1112
Steve Fuller.
Thanks for the quick reply
Time to go shopping!
markrobinson is offline
Old 10-14-2010, 03:05 PM
  #1113
I tried the Tamiya TA05 spool cups, they do not fit the TCX spool.
rccartips is offline
Old 10-14-2010, 03:09 PM
  #1114
STLNLST's Avatar
Trader Rating: 32 (100%+)
They do fit. A local guy here has them on his car.
STLNLST is offline
Old 10-14-2010, 03:30 PM
  #1115
stlnlst is correct,,,,but you have to use the black blades,,,the blades are a bit too wide, so i used my dremel to thin it down a bit,,, works great
gdcopbdcop is offline
Old 10-14-2010, 03:43 PM
  #1116
Potoczak's Avatar
Trader Rating: 120 (100%+)
Where is the cheapest place online to pick up a TCX?? And has them in stock.
Potoczak is offline
Old 10-14-2010, 03:50 PM
  #1117
locked's Avatar
http://www.speedtechrc.com/store/ebp...il.asp?id=9614
locked is offline
Old 10-14-2010, 03:51 PM
  #1118
Hebiki's Avatar
Trader Rating: 26 (100%+)
Hebiki is offline
  #1119
Hebiki's Avatar
Great minds think alike. beat me to it.
Hebiki is offline
Old 10-14-2010, 03:53 PM
  #1120
Mike Haynes's Avatar
Originally Posted by k_bojar
you switching rides?!?!
Trying one out, i ran a tcx at horsham last week and it seemed pretty darn good.
Mike Haynes is offline
Old 10-14-2010, 03:54 PM
  #1121
Potoczak's Avatar
Is there any upgrades that you guys recommend to get right away?
Potoczak is offline
Old 10-14-2010, 04:38 PM
  #1122
Well i was just commenting on them not being a direct fit.... i never tried it with blades, i know blades take away steering aswell, but i guess as a last resort they'll be ok then.
Also thanks rccartips for confirming this.
Old 10-14-2010, 04:41 PM
  #1123
STLNLST's Avatar
First on the net then on the track. Don't get use to being the first loser....
STLNLST is offline
Old 10-14-2010, 05:10 PM
  #1124
Did my first run with the car yesterday. I would probably get pink spring and the 3 hole shock pistons as a tuning upgrade.
Most of the performance effect I found came from bodies, tire choice and traction compound.
Not sure how you guys fitted the TA05 spool cups, the hole is smaller and does not fit into the TCX aluminum spool. Can you post a photo so I can also do the modification?
Thanks.
p.s. Here's my build and review of my HPI TCX. Hope I can get it up to speed soon.
Old 10-14-2010, 05:32 PM
  #1125
locked's Avatar
I'll savor this "win". Not much chance of me beating him or most other people here on the track. I just started racing this summer. Last race I finished 3rd in the b-main, so I'm more like 12th loser
locked is offline
