Hot Bodies TCX
#3601
#3602
http://www.jethobby.com/index.html
#3603
Column thickness
Hi guys, just a little question
where can I find the thickness shown in the attached files?
I would buy exactly that kind of thickness
#3605
#3606
#3607
#3608
go to HK will promo HK Distributor his product !!
#3609
Finally got a TCX after owning the TC for several years. I used my exact setup from the TC for initial setup. Wow! this car has tons of steering. Very consistent while improving my lap/average times noticably. Stock battery position I notice is no good with batteries over 300grams. I had to move in my battery more inward to get the chassis balanced with no weights.
I saw there is a narrow chassis available now. Im still unclear of the advantages to it besides chassis scrub. I know the cut outs are different. Does it provide more or less flex than the standard chassis?
#3610
#3611
new parts?
when will they release the other new parts notibly the new steering block& rear uprights? i noticed they released the new front shock tower but not the rear?......that does alot of good! ive tryed the new chasse a little better in low grip situations but not as much as the exotech, so shouldn't be as pushy as the exotech on higher bite witch i have not tested it on as of yet!
#3612
#3613
What is the effect on the car handling by using the outer hole? (on rear hub)
Did they use this solution only for carpet?
#3614
hotbodies usa is the only site i could find to buy the new parts from and they don't have the rear shock tower or steering blocks, i bought the new front spool cups,chasse,front tower & 3 hole pistons..... i'm using the front tower along with a spec-r rear tower for now...... seems ok. would be nice to see the other parts avalible here!
#3615
Im still waiting for the type C body any new news about it
