Help with setup... >
Help with setup...
Help with setup...
Old 03-03-2010, 09:23 PM
Default Help with setup...
My car has no traction..
slides out in every corner, cant throttle touch throttle around corners or it slides it, cant go back into corners cause it slides out..
even when sitting idling and it hit the throttle WOT... i cant control it or it slides out.
pretty much at the moment its sliding all over the place.
i was thinking maybe my suspension is too hard?
LiL_JaSoN is offline
Old 03-03-2010, 10:11 PM
rmdhawaii's Avatar
rmdhawaii is offline
Old 03-03-2010, 11:29 PM
Roelof's Avatar
Sounds like bad tires to me, a good tire can even a bad setup look good.
What car, and tires do you use?
Roelof is offline
Old 03-03-2010, 11:58 PM
im using 37/40
my brothers car is running 45/45 and his sticks to the track way better than mine.
Old 03-04-2010, 04:41 AM
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Default set up
what car is it ? do you know some of your basic settings, camber, and toe in, can you take pictures of car from front , rear and above view?
Speedypeterb is offline
Old 03-04-2010, 05:16 AM
Originally Posted by LiL_JaSoN
im using 37/40
Set up your car the same as ur brother's. I would make one change at a time and go out and try it and see how the changes effect the handling. But for the first change switch tires with him when he not lookin
sheeley is offline
Old 03-05-2010, 03:45 AM
im running a rrr
bro has a fw-05r.
im gunna rebuild my car, diff & shocks and put everything back to stock settings.
Old 03-05-2010, 04:38 AM
Trader Rating: 18 (100%+)
Default Help with set up
Sent you a couple of PMs with a good chassis set up
brc358 is offline
Old 03-05-2010, 08:30 AM
From what you have explained, this does not seem to be a tire or suspension issue. Even with all the wrong settings or tire choice (except for rear toe out), a car should not be that unstable. Please check all your belts to make sure there is no slip. Especially front or side.
Dennison J is offline
Old 03-05-2010, 11:57 PM
thats what i thought.. no way it can be this unstable..
i cant even turn into a corner or out a corner without it sliding out.
Old 03-06-2010, 05:11 AM
busman's Avatar
check the grub screws that hold your puleys to the layshafts, if one has backed out it will appear that eveything is proper, but on close inspection the pulley is rotating on the shaft, instead of rotating the shaft itself.
Thus 2 wheel drive instead of 4 wheel.
busman is offline
Old 03-07-2010, 11:32 PM
ill have a look
but everything seems to be spinning fine..
Old 03-10-2010, 01:49 AM
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
where are you driving the car. which track
TIX is offline
Old 03-10-2010, 02:53 AM
Roelof's Avatar
Do you run a front oneway?
If so then one of the oneway bearings could be bad or to greasy.
Roelof is offline
Old 03-10-2010, 06:34 AM
I think you should try the same shore tires your brother is using.
sheeley is offline
