Durango DEX210 Thread >
Like Tree80Likes
Old 02-06-2012, 07:39 AM
  #4186
asmazure's Avatar
I have a damaged diff ring in my new kit and with none available anywhere has anyone tried a Kyosho or Associated diff ring(plates)?
asmazure is offline
Old 02-06-2012, 08:24 AM
  #4187
Trader Rating: 25 (100%+)
Call HRP. I had broken ball studs and missing shock parts. Hooked me up and had replacements in 5 days
kerby is offline
Old 02-06-2012, 08:32 AM
  #4188
asmazure's Avatar
Already done that, they do not have any and the parts are three weeks out so I was trying to find an alternative. if anyone has any suggestions let me know,thanks
asmazure is offline
Old 02-06-2012, 08:37 AM
  #4189
Team Tekin
Randy_Pike's Avatar
Is it broken or ?
Randy_Pike is offline
Old 02-06-2012, 08:42 AM
  #4190
asmazure's Avatar
Randy,yes it looks like it was broken when it was stamped
asmazure is offline
Old 02-06-2012, 08:45 AM
  #4191
MantisWorx's Avatar
Trader Rating: 28 (97%+)
This wont fix the problem but will at least get you on the track. order a gear dif from an SC10 (2wd) all you have to do is shim inside the bearings a few mm. the kit is 25bux
MantisWorx is offline
Old 02-06-2012, 08:48 AM
  #4192
kerby is offline
Old 02-06-2012, 08:53 AM
  #4193
Team Tekin
Randy_Pike's Avatar
Please email me a picture: [email protected] . If HRP isn't helping I'll see what I can do to help.
Old 02-06-2012, 09:14 AM
  #4194
asmazure's Avatar
Thanks Randy!,I just pulled apart my Kyosho buggy diff and it looks like the diff ring from it will work! I need this to work for the Cabin Fever race this weekend we will be racing with the Tekin World Headquarters group... And keeping Potter out of trouble.
asmazure is offline
Old 02-06-2012, 09:16 AM
  #4195
drs92's Avatar
Trader Rating: 45 (100%+)
Will this car be fine outta the box to just lay down laps with or does it need upgrades right away? Durability issues?
drs92 is offline
Old 02-06-2012, 09:28 AM
  #4196
Ran mine over the last 2 weekends totaling 10 runs and 5 practice packs....... No breaks.
kerby is offline
Old 02-06-2012, 12:19 PM
  #4197
Redwings's Avatar
Default binding issue
I have just finished building my 210 and just noticed that the rear axel is binding on the against the diff locking nut. I have tighten it down, could it been that it was not tight enough? Since I've tighten it down, no binding. but diff 3 times just to be certin. Any advised would be appreicated.
Redwings is offline
Old 02-06-2012, 12:33 PM
  #4198
Team Tekin
Randy_Pike's Avatar
Nothing needed out of the box. Build it and run it.
Old 02-06-2012, 12:34 PM
  #4199
Team Tekin
Randy_Pike's Avatar
If the diff wasn't tightened it's possible for this to occur.
Old 02-06-2012, 01:30 PM
  #4200
TAMAK's Avatar
Trader Rating: 29 (100%+)
Its the same dimensions except Durango is a D ring? Very interested!
TAMAK is offline
