Durango DEX210 Thread
#2506
Mm4 is for ultra high grip tracks. I bought a second car for parts for the Spektrum race and didn't need anything from it so I'm going to build it and play around with some stuff. Gonna try MM3 to start.
#2508
Moderator
Trader Rating: 470 (100%+)
What's up fellas? I just ordered my Diggity Designs rear shock tower on their web site. Very reasonably priced. The other parts like the front tower, battery strap, and the ackerman plate should be ready in a week or so.
Order up!
Matt
Order up!
Matt
#2512
It was mentioned earlier that the hexes were rubbing on the hubs. Sure enough mine were. The fix was like .2/.3 shim between the hub and the hex. Once I did this it tightened up on the pin and hasn't fell out. Was really starting to be a pita when changing tires.......
#2513
#2515
#2516
CA doesnt stick very well to metal so they slide out with just a little effort with a small hex driver. After a small drop one or two times you get enough buildup to keep the pin from falling out even after removal. Started doing it on the desc and it worked well there, and has been just as effective on the 210 and 410 buggies.
