Schumacher Corner
#3301
National results in South Africa.
Hi there guys,after I read the post of I thought I might as well tell you how our Shumachers were dialled.In SA we only run foam tires I don't know why but we do.I touring mod I missed the A-mains by 1.33sec.Bad for me but good for the other two missions,they managed to qualify 3rd and 4th.
In the 1st final the two Shumies were dialled to perfection,Stan that qualified 3rd had a bad start and was last and in the end he managed to pull of an win.Michael fineshed in 8th.
The 2nd final was the same with Stan,he found himself last again after been taken out.In the end he managed to get 4th place.Michael didn,t even start due to his battery wires that were soldered wrong.
The 3rd and last final was interresting to watch with the guys taking each other out.Stan managed to pull off a 4th place with Michael in 3rd.
In the B-mains I was in front since lap one and never looked back to the chasing pack of TC3's.I won it in style.
In stock Michael managed to qualified 2nd and I were 7th in the A-mains out of 65 entrants in the class alone.I ended up 6th and Michael pulled of a win.
In Mod there were 2 Shummies and 8 TC3's.
In stock it was the same.
We all ran the new pulleys and X-ray rear belts.We had standerd roll centres and used the grey front belt.
Shumacher missions kick ass.
#3303
Re: National results in South Africa.
#3304
Axis Pro
Just purchased my son a used Schumacher Axis pro off E bay, needs some cosmetic's doing on it but nothing I cant handle.
Whats this car like in the big picture? Is it competitive? How old is it likely to be and are they still making them?
Its 4 wheel drive and goes real well (not that I would know if it was crap).
Let me know guys i'm keen to find out whether i'm a turkey for buying it
Mike
Mike
#3305
Don't worry the Axis Pro is a good car. They are out of production, but the entire suspension is still in use on the current car the Mission. There are alot of guy on here that used to race the Axis Pro, so you should be able to get some help with any problems.....
BTW: the car is about 3 years old now.
#3306
The Axis is a very good car and has only a few problems compared to the Mission. The biggest problem is the ever changing tweak of the car. Every time you run into something, the chassis parts of the car move slightly in relation to each other resulting in tweak. That means that the combined weight at the LF+RR tires doesn't equal that at the RF+LR tires. The other thing is that the rear belt has to be kept relatively tight for it not to skip. On track the car is really fast and usually quite aggressive by nature.
#3307
Are you gonna be running on carpet or asphalt with the axis?
#3308
Hi Ian S,
the belt is slightly longer but it free up the drivetrain.It is a aramid fibre belt which is more durable.
#3309
RW Rear Diff Pulley
Hey Guys...just got the RW Rear diff pulley, and noticed it doesn't have dust caps...do you guys that are currently running these things run them without any dust caps on them??
Thanks..
Thanks..
#3310
Mark, yea they do fine without the dust caps. I had a fence pop off of one, so I put like 2 drops of CA in a couple places on them. Other than that, they're great.
Hope we see you in Shreveport. Ron Atomic is on his way down there right now and we're leaving in a few hours. I suck at mod foam, so I'm just gonna concentrate on punting him every time he laps me... ROFLMAO
#3311
Big Dog...have fun un shreveport..I was hoping to go, but found out my wife is going to be gone so I have to be home this weekend....wish I could come run with you guys...
I may race here locally...will be my first time to run in months, so will just be focusing on retuning the trigger finger, and getting used to handling a car on asphalt/rubber again after running on carpet for so long...I havent run the car with the roll center mod yet...
#3312
#3313
Re: RW Rear Diff Pulley
Thanks..
Thanks..
#3314
Pit Racer...I ordered the RW pulley from Schumacher...I am still using the original one way..glued it together forever ago and it still works great...
#3315
Actually, the Axis is proven to do better on asphalt then the mission does. But on carpet the mission rules. The Axis models are very good and effcient cars, if your gonna run asphalt your axis will do awsome. A honda blade, whats that? a motor cycle?
