Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 12-14-2007, 08:34 AM
  #23851
Trader Rating: 37 (100%+)
hey Adam
Do you think you could post what you told me about the schui spur gears the other day.
I couldn't remember what you said and when we might be expecting the new one's to role out.
Bertetto is offline
Old 12-14-2007, 08:36 AM
  #23852
hey belt buckle, can I borrow some of those foamie's???
I will give them back when I'm done.
Bertetto is offline
Old 12-14-2007, 08:57 AM
  #23853
R/C Tech Elite Member
abailey21's Avatar
Were working on getting a 90t and a 102t 64p, but this was just agreed upon and there isn't a definitive time line for arrival as of right now.
I will be on here as I learn more on this and let you guys get them on order as I know more.
abailey21 is offline
Old 12-14-2007, 09:38 AM
  #23854
Customworksking's Avatar
Trader Rating: 74 (100%+)
Default what
lol your good we can work something out
Customworksking is offline
Old 12-14-2007, 10:36 AM
  #23855
seaball's Avatar
Wink don't try to be a hero
Originally Posted by Randy Caster
Now for the foam fanatics, I need some help I'm going to be running mod foam at Snowbirds, gonna start with Goetz' Cleveland setup. So if you're around Chris, what is the difference between the rear hubs on your car and the Schumacher 1 degree hubs.. which mounting hole should I use on the Schuie hub? Any changes you'd make to the setup to make it a little more aggressive for mod, or should it be good as it is? Thanks!
oh man, you rubber guys should know better. it just never quite works out right.
that kit setup is still a really good starting point, generally speaking. for mod, you might start with 6* castor blocks. from there, a stiffer rear spring, more front camber gain (inclination), shorter links (rear for exit, front for entry), and another mm higher for the rear roll center. all of that should be more than enough. (actually, it should be flipping off the track with all those changes.)
that's all i got for you, sir.
- malfeasance gramatica -
seaball is offline
Old 12-14-2007, 10:59 AM
  #23856
Trader Rating: 42 (100%+)
90T 64P would be sweet. Then we can go back to human pinions under 40T.
Oh...anyone want a Mi2 rear diff...cheap! Right Adam :P
Nexus is offline
Old 12-14-2007, 11:15 AM
  #23857
abailey21's Avatar
HA! even
Yeah were looking forward to the 90t, I don't know if Robinson likes that, I'm sure they've paid salaries on 43t pins lately...lol
Old 12-14-2007, 11:17 AM
  #23858
Skiddins's Avatar
U3169 Ti 55mm Pins are NOT threaded
I run the standard items with the screw partly undone and held tight with threadlock, and that's only so if I crash and have forgotten to do up some of the pivot screws, I don't end up with half my suspension spread across the track.
Skiddins
Skiddins is offline
Old 12-14-2007, 11:19 AM
  #23859
POUNDITRACING's Avatar
what kind of FDR do you guys run with a 10.5???? I run 5.1, but I keep hearing 4.5 and 4.1.
POUNDITRACING is offline
Old 12-14-2007, 11:32 AM
  #23860
abailey21's Avatar
thats sounds closer to 13.5 FDR, I'm running 4.97 with mine right now, and I see many people running lower than that. 6.5-5.0 on the 10.5's from what I'm told is what a lot of guys are running.
Old 12-14-2007, 11:37 AM
  #23861
That's what I thought. The guys that are saying the other stuff aren't any faster down the stright.
Old 12-14-2007, 12:04 PM
  #23862
AdrianM's Avatar
I ran a 5.75 FDR with my novak 10.5 at SS Speedway.
AdrianM is offline
Old 12-14-2007, 12:06 PM
  #23863
abailey21's Avatar
Is that the same motor you smoked Wednesday night?
Old 12-14-2007, 12:17 PM
  #23864
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
4.89FDR with my Orion 10.5(about 1mm degree advance timing)
Marcos.J is offline
Old 12-14-2007, 01:03 PM
  #23865
Randy Caster's Avatar
Trader Rating: 47 (100%+)
haha I was hoping it would just be 1 or 2 simple changes, not a whole new setup
Can you PM me your # again, I dont know what the heck happened but I got 2 #'s for you and both are wrong, lol. Just want to pick your brain for a few mins so I know what to do when something doesnt work as planned
Randy Caster is offline
