Schumacher Corner
dude,its an 8 minute race,well worth the drive!!!! happy anniversary bro.
Originally Posted by P-DUB
A 50 minute drive on my 6 year anniversary to say hi might not go over so well, but we will see what happens
Originally Posted by HarshGuy
Do what I do ...tell her "It's my anniversary to, I chose to celebrate it this way"
A little inside info...All the Tamiya guys used up my Schuy grease at the IIC
i herd there was teemu running the prototype of the mi3?
does any1 know any thig thats has been changed form the mi2ec?
Read backwards from [HERE]
And come to your own conclusion :-).
Schumacher and all other manufactures are always testing new stuff; once there are enough changes to a certian model you will start to see complete prototype cars
kk i also heard about schumacher making a split bulkhead for the ec so u can get the diff out quicker is this true that there making 1 and if so how long before it come out?
No prototypes at any races thus far. Teemu and the rest of the team are all still using Mi2EC kits. Although it is part of the team drivers job to better the products and test new things. Many times drivers will make their own prototype parts to test.
Skiddins
plus 12 screws can u let us in on the secret?
Skiddins...There is always room to make it better and easier to work on. I think that is one of the things we need to work on
Undo the 4 for the shock tower, the 4 for the diff carriers and the 2 for the top deck (if your doing the rear you will also need to loosen some of the other top deck screws)
You can lift the shock tower slightly and the diff carriers should move about freely, I usually twist the diff slightly etc which lets the driveshafts come out, then you can remove the carrier, now the diff itself
I used to only 'loosen' the diff carrier on one side, but it is a bit quicker if they're both loose.
Skiddins
Gotta mix it up with the Socal guys for the region 12 asphalt race this coming weekend. I was going to take time off but I guess I need to get one more asphalt race it...LOL
