Ask Paul Lemieux, RC America/MOTIV/Gravity RC
#2656
Regarding tight in and loose off... What I've seen quite often on carpet is that with a really pushy car, you can use too much steering throw and force the car to turn, but it's all bound up. Then when you get on the power you've still got the wheels turned too much, the front digs in hard, and the car doesn't want to straighten out, seeming like oversteer. Making the usual changes to tighten up the car then makes it worse. Changing the setup towards more steering can actually solve it.
But of course as Paul mentioned, if your rear diff is bound up, that can make it kick out. Also if the rear belt is too tight relative to the front, that can make the rear kick out when you get on power, too.
-Mike
-Mike
It is his first time driving with a spool. I am sure that is a learning experience for him.
#2657
-Mike
-Mike
Im sure hell do fine! well get him going.
#2659
A found a comment by another racer made in the 1/12 scale thread. No one managed to answer his question. I too am curios to find out what your opinion is.
"Just out of curiosity...
Suppose I'm running maximum caster at my front end (all 3 shims to the front) and 5* Blocks.
What would be the difference between:
moving a shim to the rear...
or changing to 10* caster block
I already know the reactive caster allows you to have more in the straights, calming the car, and less in the corner, allowing the car to turn in harder.
I just want to know under what situations would it be better to make static caster changes vs. reactive caster changes."
Cheers.
Cheers.
#2660
Hello Paul,
I drive in a medium-big asphalt track, I have thunder power 4.5 motor an HW speedo, what timming do you recomend for the motor? and ratio? can you send me a setup for the speedo?
Thank you in advance
#2662
Sorry I have duplicate post
#2663
Cheers.
Cheers.
This set up was good for me on carpet.
http://forum.teamxray.com/xform/inde...&setup=t3_2012
Thanks!
#2664
Thank you Paul!!!!
#2665
Thanks Paul
#2666
Hello Paul,
I have test and I am happy with the acceleration and top speed, but I have a problem braking I have nearly all 100% and I don't get enought brake after the straight and we have a hairpin, what can I do?
Thank you
Thank you
#2667
I Haven't played with brakes yet but i suppose go to 100% brake on the speedo settings for starters.
#2669
Thanks again Paul for the tuning help at the Nats! Your sponsors could not have a better rep. That was an unbelievable show of driving talent as well.
My son is definitely a new fan. I'm glad he has a good role model. Get some more Gravity Products out there so we can show some appreciation that way as well!
Augie and I look forward to racing with you again. We sure wish Colorado was possible for us. Sounds like a blast!
#2670
