Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#1128
I run a Lajf Racing widened X10, other cars at out track is the CRC (wide and in 200mm config) and a Serpent S100 in 235.
#1129
We use Associated RC10R5, CRC Calandra, Corally 10SL, Xrays X10 link, RCDevil PC10H3X. CRC is the car most people have here. One friend wants to convert his Yokomo 1/12 to 1/10 with a conversion kit available.
#1131
#1133
can anyone confirm that this part will fit a 10L2 pod? CRC 13361
http://teamcrc.com/crc/modules.php?n...prodID=7718872
it looks promising since i 'think' the CRC t-bar and side plates were interchangeable with the 10l2?
thanks for the history lesson.
#1134
#1135
Does the wing come separate or is it molded with the body? Can't tell in the picture.
#1136
I just had a peek. It's molded on. it looks like it could be trimmed off and mounted on wire if need be.
http://www.stormerhobbies.com/cgi-bi...c=ns&pn=MCA123
#1137
Bob, do you ever sleep?
I left mine in the original (as molded) position, and also didn't cut out the area between the body and wing (just masked it and left it clear) since the speeds on our indoor track don't require the downforce, and the extra strength is useful. That's assuming that the downforce is improved by cutting the plastic, which I haven't yet determined.
If you cut out this area, then it's possible to adjust the downforce by blocking off some of the cutout with clear tape.
One nice thing about the Jaguar: it has the widest front end of any body I've used: 233mm. There's plenty of protection for the front wheels, even at full steering lock.
#1139
Bob,
What else is there to do in Glasgow, Montana??!! I want to come out an visit the place, but I'm not sure what I'd do after that! I looked at Glasgow on Google Earth and didn't see much. However, listening to the Hog Report while on hold is a highlight of making an order with you!
Scott Franklin
Doing this for more than 25 years.
Scott Franklin
#1140
Bob,
Scott Franklin
Scott Franklin
Hopefully though, you never get to hear it and we get you handled FAST!
Small town radio...
