Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#211
Flyer added. Only 75 drivers can enlist so hurry up
#212
It will be a great event so if you have the chance to enter it... DO SO!!!
The Rucphen track is a great track with nice bends and some high speed sections in it, you can really unleash the beast in your RC car. Also it will be taking place in the end of july so the weather can be pretty good and when that happens there will be tons of grip!!!
#213
I forgot to mention that there is a camping site right on the tracks premises.
For those in Europe (or if you are going for a holliday to the Netherlands )there is going to be a Benelux+ race held on the 23 and 24 juli 2011 on the beautiful and highspeed track of the Baanbrekers in Rucphen, The Netherlands.
Benelux+ means BElgien, NEtherlands and LUXemburg and the + is the rest of europe .
The pro10 will have two classes: 10.5t and modified.
Website:http://www.macdebaanbrekers.nl/index.html
To register: http://www.macdebaanbrekers.nl/beneluxraces_eng.html
Circuit: http://www.macdebaanbrekers.nl/hetcircuit.html
#215
Lajf Racing X10 Link Widening parts
X10 Link 235mm parts:
check out Lajf Racing: http://lajf.se/en/produktnytt/fler-x...n-lajf-racing/
#216
Hey guys...
It took al little longer than I had expected but it is finally here... My new Pro10 creation which will be called the: P235-CS
I designed the chassis from the ground up instead of enlarging a 12th scale chassis with some modifications. I still use some Team Associated parts like the center shock and the R5 side shocks as well as the R5 front suspension. The main chassis is a lipo chassis which no longer has slots for NiMh cells in it. Also it features a longer rear pod equipped with IRS extended pod plates which move the rear axle 10mm further to the rear to create more gearing options than the R5 podplates. The car has two side shocks and a 10th scale T-bar with metric hardware all around (even on the IRS podplates which I modified by tapping M3 thread in them).
A future option will come also from IRS again in the form of height-adjustable casterblocks and delrin upper arms. With this option I will be able to change the height of the upper arm to adjust camber-change in the car.
On the last picture you can see the "old" version in the back and the new car in front... ENJOY!!!
Greetz Joost.
Greetz Joost.
#218
Thanx!!!
The wheels are the new Team Shepherd Tires with Enetti rubber mounted on them...
#220
Thanx mate!
The tires are the asfalt type from Shepherd and they work very well. It is the same rubber that Xceed uses, both Enetti. I mostly use Foam Liquid from Mobers which works fine for me.
#224
