Serpent 733 1/10 200mm touring
#616
Dodge Stratus and I use the ackerman inner rear.
DJ Apolaro
DJ Apolaro
#620
What's it for?
At the right front corner of the radio tray, molded in the servo cover is an ovoid 7x17 mm flat surface with two 2 mm holes in it. Vas ist?
#622
Has anyone had to shim up the servo saver shaft so that the servo saver doesn't hit the radio tray
#624
Thanks DJ, I ran the Blitz Altis 2.3 and the Stratus back to back and the Altis has the most steering but it is tail happy. The Stratus felt neutral as usual but on the 733 it turns really well. I'm going to work a setup around the Altis, see if I can take advantage of that steering and all that straight line speed.
Ackerman wide forward
#628
If I do that the tension nut hits the belt this is the first snag everthing else went in perfect should i shim up the whole servo saver
