Serpent 733 1/10 200mm touring
#631
Nothing is binding it just barely rubs the side of the belt and i need like 2mm to clear I trying to take pictures now
#632
I figured it out the shaft the the tension nut goes on was on in place in the upper part of the servo saver
#634
#635
Got to see one run last Sunday at Crystal Park while I was out there praticing and I must say that car is FAST.
Another gentlemen that was pitting in front of me was building his at the track and that car is beautiful. Completely new car from the ground up.
Once I get comfortable with my 720 I will replace it with a 733 with no doubt.
I'm sure everyone that has theirs is enjoying them.
#636
I've complete the front of the 733 and found that my front belt is rubbing against the part where hold the steering post. excuse mi cuz i dont know what should it be called. ( Enclosed Pic )
Is there any other way which i can get rid the front belt from rubbing.
#637
mine is rubbing as well. but its not a big deal. will probably 'skin' the belt after the first run and all will be well. does not bind the drivetrain at all - at least mine.
#638
welcome to the snake club
#640
Fatboy from your pictures it seems your left Toe link in more on the inside rather than the outside like the right side.
I should make toe adjustments interesting
#641
Fatboy you hex nut inside the upper part of the servo saver its not seated in its correct spot. Look at the middle picture there is an indention for that hex to sit in
#642
Just another tip. We are using associated diff lube. The small clear bottle for the one-way bearing. It helps it last even longer than normal.
DJ Apolaro
DJ Apolaro
#644
#645
