STS engines
#946
If you come from North America and have any problem of your STS engine,contact with ProjectZen first. They have good service.
#947
Finally got to run my Zen mod D3r overall i was happy still need to tune didn't have enough time to tune and try set ups. the motor got faster as the day wen't on but i do wan't to try different plugs had a #6 i'll try a #7 as per Geoff, there were only a hand full of cars pulling away on a 230 250 straight but from my D3 to D3r i'm happy had a couple of guys say to my pitman that my car was fast and geting faster i'm not giving up just yeat on it
#948
Here is some good news, first killed a few itailian motors, ranging from MR, NS and X12 with special sauce.
I can say, bottom end to mid range power is very smooth and it is not sluggish at all, top end has good power but not as fast as those NS even so I still took another guy with NS12 at the end of the back straight entering sweeper which felt great! I guess he has to back off just a bit and I didnt have to so I can pretty much full throttle into the sweeper. You can say the motor is not as fast as those itailian but yet It is faster with controlable power!
Bottom to mid is great! most kill right here, even if they gain on the back straight and after 2~3 turns the next thing they know I am right on their ass already!
Overall, from all the motors I have had, this is probably then second best motor.
*one side note, I was running the D5R with STS one piece pipe(no shim on the pipe)
Keep up the good work!
one last thing dino, do you guys have those STS stickers? I am getting tired of answering ppl what motor I run, if I have a big ass sticker on the wind shield then I dont have to do that that often!
#949
dino, very nice engines, hope you guys keep improving.
data
#950
data
#951
Originally posted by Data
your d5r seems to accelerate better then mine, maybe the pipe has something to do with it or maybe the gear ratio different between our cars. next time i am going to put the d5r on the mtx-3 and run with you again. let me try that sts pipe next time.
data
data
#952
All right, I am running 21/27 with 59/52 on mtx3
hmm... only 1.3% different at 1st gear, i think either i am going to put the evo through some weight reduction program or ask you guys teach me how to tune enignes. $#d%^i$@n$%^o#%#h%#$e%#%l#$#%p !!!
by the way, you have my screw driver ?
#953
#954
WAHAHAHA.....That is what I always say....DO YOU JUST STEAL MY SCREW DRIVER?
#955
thats ok, i have his header spring hook. i have many flat head screw drivers, he only has one spring hook.
#956
Originally posted by au_Nightmare
I seen a aussie ebay advert for a D5.. "only raced once and was run in correctly, total of 600cc fuel through engine". The D5 takes over 2000cc of fuel to break in so it was not even 1/4 broken in when it was raced, buyer beware...
#957
Originally posted by Rabbit
Hey Guys.. im new to this thread and the lucky winner of the ebay auction above. I havent run the engine yet, all the internals seem nice and tight/heaps of compression. Any tips on what to look for to see whether this engine has been damaged?
1. check the piston and check if there are any scratches or dent
2. check the sleeve and see if there are any scratches
3. remove the p/s from the engine and see if you can push it through the top, it you could then p/s is gone
4. measure the crank pin vertically and horizontally and see if they are about the same size.
That's what I could think of and hope it helps
#958
Threaded Crank
I have also heard that novarossi and STS parts are similar... would i be able to take a threaded crank from a novarossi C12 and put it in my STS?
#959
Re: Threaded Crank
#960
au_nightmare giving you nightmare huh ?
