TC3 Forum
#5161
Originally posted by TigeRyan
I have one other thought similiar to the last gent....
Make sure you have replaced any ball cups in the steering linkage with RPM ball cups they are thicker and may run on the chassis and catch and they will require a slight tap to get past that point, and depending on the angle it could only happen going one direction....
Just another thought...
HTH
HTH
and also no protusion from the ball stud on the rack
i'm pretty much stumped by this problem....
#5162
wiley
okay, are you using the same reciever for your cars?
maybe there is something wrong with the reciever on your TC3.
Looking at my car right now, since I am rebuilding it also.
It's like a "twilight zone!" with what ur going thru. heheheh
#5163
Re: wiley
#5164
If you want the best ball cups on the market....and I HAVE tried them all.....use the Schumacher ball cups. NO SLOP! Super strong (look at the abuse the Schuie's get)....
I use the Schumacher ball cups with titanium ball studs....perfect setup. These are also thin at the top of the cup....so they will NOT rub on the inside of the rims..etc..etc.
#5165
Those ball cups are hard to pop on BUT theyr'e equally hard to pop off too.
#5167
the easiest way is to unscrew the lower shock mounts then open the diff case enough to take out the front input shaft and you can then get the shaft out.
#5169
FT TC3 Front lower arm breakage (version2)
Hi to all,
need help. I have had my FT TC3 for about 2 months and in this time i have broken 3 Front lower arm (version 2). It happens every time my car hits the side kerb. even when off throttle (i am using 15 turn). I am curious why i keep breaking the arm so easily when it is graphite. I noticed that it breaks at the area when the suspension arm is screwed into the lower arm.
Have any of you had this problem?
Can i solve it with a stronger and bigger bumper?
Also, will after market arms be better? How about the normal arms (non graphite) be compared to the graphite ones?
Cheers
Cheers
#5171
Re: FT TC3 Front lower arm breakage (version2)
Originally posted by ASWK-TC3
Hi to all,
... I noticed that it breaks at the area when the suspension arm is screwed into the lower arm.
Hi to all,
#5172
Front Lower Arm (version 2)
Hi,
you are right. SOrry about the typo error, i meant where the suspension is bolted to the lower arm.
Cheers
Cheers
#5173
In general, the stock plastic parts will be more forgiving since they flex more before they break ... however the graphite ones are more rigid and in turn will snap easier than plastic ...
#5174
Re: Front Lower Arm (version 2)
Hi,
Cheers
Hi,
Cheers
just wanted to clarify what you were referring to ...
#5175
Re: Re: wiley
Originally posted by wiley
different rx....i'll try to change to another receiver...will let u know the outcome...car is in pieces right now
