The Speed Passion Thread >
Like Tree57Likes
Old 03-10-2013, 10:46 PM
  #11311
Trader Rating: 22 (100%+)
Originally Posted by Snafujg
I'm looking to get a Reventon Stock Club ESC to run blinky 17.5 in my 2wd SC10. I have a Savox 1258 in the truck. Anyone experience brown out issues with this combo? I know the Savox are power hungry. Just want to make sure the ESC BEC is up to the task of a Savox servo before I buy one.
I have the Reventon Stock Club ESC with a Savox 1251 and a 17.5 and didn't have any brown out issues. No guarantees as it was my first day with this combo but I have not any any brown out issues with any SP ESC with a Savox.
Great ESC too, comes ready out of the box, wires on, Dean's connector on, fan mounted, ready to rock.
Troy Carter is offline
Old 03-11-2013, 12:01 AM
  #11312
Originally Posted by quickershifter
I can't get my Rev R to on the turbo/boost. How to set it up? I'm running Yeah Racing Hackmoto 13.5T BL motor.
Update ESC firmware to "Stock1 V19-58b7 - for Reventon R" by using Reventon PC interface V1.1.0.22. Adjust setting "Hybrid Boost Power" and "Hybrid Boost Maximum". Ensure ESC and Motor have connected sensor cable.
WMGary is offline
Old 03-11-2013, 11:29 AM
  #11313
Trader Rating: 17 (100%+)
Default Reventon Pro Setup Setting
Any good settings for 17.5 Blinky? Wanted to see if anyone has a good starting setup.
Thx.
DJGonzo69 is offline
Old 03-12-2013, 06:40 PM
  #11314
Hey guys, need help with a starting setup and FDR for a Reventon Pro in 21.5T boosted. Going to try this class again, last time I blew two motors trying to get a fast setup so don't want to repeat that mistake
ript is offline
Old 03-12-2013, 09:55 PM
  #11315
Thx.
1-1
2-3
3-8
4-8
5-1
6-3
7-1
Start at 4.0 FDR and 30-ish degrees of timing and add teeth and timing as necessary.
Danny-b23 is offline
Old 03-12-2013, 11:34 PM
  #11316
ScottyTC4NZ's Avatar
Default Reventon Pro Setup with Yeah Racing 21.5t Open Setup
Hi Guys
Looking for a setup for the above.
Track is Low Traction Mixed Track with 65metre main straight
Also will need FDR to run with aswell
ScottyTC4NZ is offline
Old 03-13-2013, 01:18 PM
  #11317
coretex's Avatar
I have programmed my Reventon R to do forward/reverse. However I have a problem with it: It won't always do reverse. I pull back many times on the transmitter but nothing happens. It seems to do reverse sometimes but not always.
The strange thing is that the brake function always works fine, so there is nothing wrong with the signal...
coretex is offline
Old 03-13-2013, 02:06 PM
  #11318
Originally Posted by Andy w
As I said in my post, mine DOES work with a 1s. It works with either a rx pack or booster. I am trying to figure out why when it supposedly shouldn't.
May I know what booster you use..? I would LOVE to know that...cause I have this question asked so many times and I have no solution, until now...
When was your REVENTON S or R purchased..? I want to know too...
Solara is offline
Old 03-13-2013, 02:14 PM
  #11319
Originally Posted by akisole
Every time i load a new software i recalibrate the speed.The timing in x20 is the lowest 4dot 27.5 the other is 30, 32.5, 35 and 37.5.
I will tell you exacly what it made me.
For the first 30 seconds the speed work in full throttle.after that when i keep the trhottle in 1/4 for 1 sec(entering a corner) and give all the thortle exiting the corner the car goes with 1/4 of thorthe.I dont have full thortle.When i leave and give again full thortle gives me 3/4.I work it like a nitro with playing all the time with trhottle to work.
I play
Drag Brake Force 15%
Low Voltage Cut-Off 3,4v/cell
"DDRS" Start Mode level 3
Maximum Reverse Force 50%
Initial Brake Force 0%
Neutral Range 6%(Narrow)
Turbo Open Time 12 deg/0.1sec
Boost Start RPM 9000rpm
Turbo Open Delay 0.2 sec
acc 750
I think you are running SENSORLESS mode after the full throttle....when you are running sensorless, you no timing, no boost..that explained the slow throttle with no top speed or boost...
It is sensor problem....either your sensor cable, or the sensor board inside the motor is bad....the last thing, the sensor port of the ESC is bad. Check all 3 items...
Solara is offline
Old 03-13-2013, 02:19 PM
  #11320
Originally Posted by EDWARD2003
Okay.... were in Japan can I purchase the greening timing board for MMM motors?
Tresrey.....
http://www.tresrey.com/
Solara is offline
Old 03-13-2013, 06:27 PM
  #11321
Andy w's Avatar
It is a R and used a old Novak Smartboost that I got 2nd hand. I also used a LiFe rx pack with it and it worked. It was paired with a Reedy Sonic 13.5. Everything worked as any 1s has worked for me in the past.
I bought it from the SP website on Oct. 12. At the time I used the firmware that it came with and have since loaded the stock0 firmware for my TC.
I know I didn't dream this and the only reason I switched the esc is I had a LRP SXX laying around and it made my chassis cleaner without all the extra wires and battery. When I can I will switch it back and see if it still works with the new firmware.
Andy w is offline
Old 03-13-2013, 07:20 PM
  #11322
Maybe re-calibration will solve the problem.
WMGary is offline
Old 03-14-2013, 08:16 AM
  #11323
I am going to try that...thank you Andy.
Solara is offline
Old 03-14-2013, 05:15 PM
  #11324
askbob's Avatar
Trader Rating: 29 (100%+)
Finally got the Reventon S going in my buggy last night and the Wifi module working today. Very smooth control and the Wifi module is the cats a$$! I see that there isn't a 'hybrid boost' setting with the S model. Are there any future plans to incorporate this setting into the S model?
askbob is offline
Old 03-15-2013, 01:49 AM
  #11325
when new software will be released?
Stock0 has serious cogging at low throttle
guru83 is offline
