The Speed Passion Thread
#9572
I think there are more super 7 coming on couple weeks...
One thing we are testing right now...the silver red 12.5mm high torque...gear to the MARS on 17.5 (sub 3 final) and stay with 140° with +20 timing...will test a little less gearing but yellow timing ring and see is that the magic answer.
#9577
Just some ROAR update.....all the SP advance timing sensor board are now ROAR LEGAL, as well as the 12.3mm/12.5mm super 7 purple/red rotor are ROAR legal as well....
Reventon "S" series are instock now....it is a 40A entry level unit, perfect for blinky no timing spec racing...ROAR approval pending. It can be software updatable and it will come with the USB equipped LED programmer card standard. So you don't have to buy the extra USB connector box anymore. OR...try out the WIFI and BLUETOOTH device for wireless connection.
Reventon "R"....possible within 3 weeks ETA.
#9578
how do i update reventon iphone app firmware list??? saw in youtubee there is an online update button...but my app dont have de button n the update firmware list are empty... try to use pc app on mod1 there is no super charge setup?? tq
#9580
Shop Owner
I have installed the 428stock firmware on my speedo and used settings I had with the 323stock installed previously running the 1cell 5.5 on touring and car was noticeably slower.
Didn't have time to test settings as I had other issues , question is there a suggested way on converting settings from 323s to 428s?
#9581
speed was not far below what 323 stock was on exact same settings, but i can tell you temp was barely over 40C. where 323 was more around 70-80C
so i upped the boost and added some turbo. Oh Yeah ! this is a Rocket now, with temps stable at 60C. had some dramas last final, completed 9 laps, im just wondering if i put a charged battery in. Ooops.
settings were
3.5t V3. timing middle. FDR 8.5
428 stock.
50% brake, 25% reverse.
non protection
DDRS 4.
boost timing 36 deg.
turbo ramp 0.6
turbo 8
0.3 delay
600 ACC .
Temps are very stable, even i forgot to plug the motor fan on, and came in at 65C. but very fast.
#9582
i will be trying mod again next weekend in my TF6 , any ideas for a base set up for a V3 6.5 motor and the new 428 software ???
i dont want to use the 4.5 MMM just yet as the belts are old and i need to learn slowly ;-)
thanks Phil
thanks Phil
#9583
Higuys downloaded latest sw version 1.38 from sp website ok...tried to update my program box but unable to load latest sw on the choice sw version box only comes up with
V1.07_100119
V1.06_100617
redownload sw1.38 and reinstall still same .....any help would be greatly appreciated
V1.07_100119
V1.06_100617
#9584
V1.07_100119
V1.06_100617
V1.07_100119
V1.06_100617
plug in the speedy to the program box, load up the 1.38 software on the pc, then turn on the speedy. then i got to software tab and update your speedcontrol software, it should have a choice of a newer version as 428 then upgrade from there. then always reset your radio to speedy after software changes.
#9585
Also what is happening at the moment with the 21.5 ultra sportsman/cirtix combo? Will that remain or will a new package come out with the reventon s? Need to provide a proposal to my local club for next year for a spec motor/esc but they won't accept something if it isn't going to be available.
