The Speed Passion Thread
#6961
Trader Rating: 32 (100%+)
#6963
Hi all
I have a speed passion v2 lpf which I have never upgraded.
I have been racing for years at my club and although it's a very tight track (the longest straight is 15m) however we use 8.5 -10.5t motors in the fastest heat with our TC's
As you can expect a 10.5t usually wins as it's more consistant, as the infield is very tight so there is a lot of sharp corners where you scrub a lot of speed.
I was wondering, would a 13.5t boosted be a better solution? Keeping things smooth on the infield and boosting on the straight? Or would I just be too slow?
Also is boost useable on such a tight circuit? The straight is usually over in less than 1.5 secs?
Cheers
Cheers
#6964
speed passion firmware updates
it's been so long ago,, speed passion did not release the new firmware ?
#6966
Oops. Didn't see your edit. I'll leave post up anyways if anyone else is reading and needs info too.
#6970
For me...the 1S motor looks BETTER. My car is always slow...so does my driving, but I do that in purpose cause I want to see my motor looks good on the track....LOL
#6972
Hi guys
I have a problem with my speedo, it's a speed passion 2.0 pro and i run the hobbywing 119 firmware on it and has been fine, until now.
it wont let me up or downgrade it through the 2 in1 box or pc and has made the display on two boxes go blank.
any help would be great
#6973
#6974
Hi guys
#6975
I just purchased a Cirtix Spec Stock ESC. I can't seem to get it to setup. I'm using a Helios X-10 and Ballistic Motor. I've tried an older Novak SS as well, but after the set-up process, the ESC still stays at neutral. I've tried reversing the throttle on the Rx, turning the epa from 150 to 100, but nothing seems to work. Can someone give me some idea what to do?
