Kyosho Evolva
#541
in the JMRCA last week, the evolva was still performing very well and they beat the MRX-4.......
http://www.jmrca.com/2004all_japan/8...cing_main.html
#542
Re: Re: 321p
Originally posted by speedy100
hey, does the new 321P has the red silicone molded in the crankshaft ?
#543
Re: Re: Optional Springs
Originally posted by C Verano
Check Tower's web-site...The colored springs start at FM368.
#544
opps. wrong forum..
#545
Re: Springs
Originally posted by manokgt4
too bad. Tower does not have any picture of the springs i wanted. Can somebody tell be the part number of the yellow springs front and rear? thanks in advance.
#546
Re: Re: Springs
you can try the mugen spring as many of them have good result, they recommend the white and red color
#547
Re: Re: Re: Springs
thanks Speedy. Actually, i've been running that white and red set-up for the longest time. figured trying out kyosho's optional springs.
#548
Originally posted by raceblast
hi jwf-ronni:
Have u finished making the charts of the spring rate of different springs yet?
hi jwf-ronni:
It's basically done. Sorry I've been away busy with stuff. But I
will send it over to you as soon as I have access to my home PC
this coming weekend.
#549
Front belt
Does anyone know if Fantom front belt fit Evolva?. Upon inspection today I found out my front belt has gone a few teeth and my LHS has't stock Evolva parts yet, but he's got Fantom belts, and to make things worse, this weekend we will have a big 1/8th race. So if any of you has tried the Fantom front belts or any car's front belt (Mugen/Serpent) in the Evolva with success, pls advice me.
Thanks!
Thanks!
#550
Re: Front belt
Thanks!
Thanks!
#551
Where can i get FMW25 option front belt on the net? Preferbly from HK site or japanese site.
Thanks!
Thanks!
#552
You may get the belt at gm models.
But I heard the delta xp4 belts are more durable than even the optional Kyosho belts. They are the same length.
http://www.gmmodels.co.uk/acatalog/O...Parts_118.html
#553
Thanks!
Thanks!
#554
Front belt problems?
So even the Evolva is not immune to the front belt/small 16 pulley problem? Too much power on these 1/8 scale cars is revealing the weakness that may cause me to just go back to 1/10 scale sedans. It's more fun to be running than fixing belt problems in the pits. What's worse is you know you'll be breaking it again and again.
#555
i've been using Takagi belts for quite sometime now. Since then, i have not replace even one of them.
