T.O.P. Racing "Photon" 1/10 EP Touring Car
#4098
#4099
Remember to clean the shaft before trying to remove it, otherwise the grinding debris will cause a similar problem.
This is one of the reasons the new steel shaft came out.
James
#4101
If you have the aluminum center shaft it more then likely has mushroomed slightly on the ends from tightening it. Causing it to be darn near impossible to remove from the bearings, lightly grind the OD of the shaft till it will slide out.
James
James
#4104
Thanks . . . .
__________________________________________________ _____________
Also anyone know where I can get one of these ?
Thanks !
#4108
#4109
PHOTON
Here is the start of my State Champs win.Photon was ballastic all weekend!I am on the pole!
http://redirectingat.com/?id=42X1295...-wheels-7.html
