Serpent 710
Originally posted by Sow&Steady
Unless the currency converter script on my website is wrong, then it seems that the-Border's price is really expensive!
USD 26 = Euros 20.9 at today's rate. Even with postage .... well never mind
Winner's Circle
http://www.gasrccar.com/
or
Ashford Hobby
http://www.ashfordhobby.com/
Look at what the chassis plate costs here and at Mushroom. The normal price in Europe is 70 Euro (US$ 85+) and I believe at Mushroom you got it for $40!
Look at the new arrivals at Mushroom, the Serpent ceramic bearings. I don't even want to know what these cost here in Europe!
1380 5x13 (2) $23.31USD
1381 6x10 (2) $25.06USD
1382 6x13 (2) $23.31USD
1383 6x15 (2) $31.33USD
1384 10x15 (2) $31.33USD
1386 12x18 (2) $31.33USD
1387 12x21 (2) $37.60USD
With the cost of those bearings you probably could buy 2 sets of the Acer ceramic bearings.
Originally posted by PSI Racing
Geez!!!
Geez!!!
You need:
8x 10x15 = 4x 31.33 = 125.32 (wheelaxles)
4x 12x18 = 2x 31.33 = 62.66 (diff eccenters)
5x 6x13 = 3x 23.31 = 69.93 (2speed+2speedshaft+midshaft+1 "spare")
1x 6x10 (flanged) = 25.06 (2speed+1 "spare")
Total: $282.97
Not including 5x10 (2) and 5x10 thrust for clutch, 7x14 and 6x14 thrust for diff.
Originally screamed by KevinS' wallet
OUCH!
OUCH!
Re: Re: Re: Serpent 710 tips!
Originally posted by PER-OLA HARD
Hi Mark,
Thanks!
Front: yes the alu is more stabile so the small M3 insex screws works better then they touch the alu levers instead of the more flexible parts.
Rear: I drilled the holes to 3.3mm and replaced the standart M3 insex with a M4. Works nice I think!
Cheers!
/Per-Ola
PS. I will check in here now and then....
Hi Mark,
Thanks!
Cheers!
/Per-Ola
Great tips, thank you.
Hi!
I am new at this popular forum!
Hi!
Originally posted by cyba888
When you adjust the drag brake do you not only adjust it from the brake linkage screw but on your transmitter as well? Incase it starts to fade I was hoping you can adjust it using your tx? Is it possible without interfering with your carb settings?
Re: Re: Re: Re: Serpent 710 tips!
You've sold the idea! I'm going to online to order the Al parts .... swoosh!!!
Originally posted by markp27
Mine varies depending upon amount of dirt but at the moment, I'm upto 1719 with Stratus body - this is without the alu parts, but with a lot of much too expensive ti screws
Originally posted by InitialD
I guess you could adjust the brake fade on the EPA a tad or two. The throttle side would have the spring there in the linkage and that extra movement would be absorbed a little by the spring. But not too much as this will strain the servo.
Re: new 710 driver
Originally posted by impalabob64
My eng. Jp modified,gear setup 18/61 23/56.
p/s: I noticed you used the G4 previously.
You guys are fast.....
Weight: with small tires and a Mazda 6 body around 1715 gram, no small servos or anything.
Also, in the LRP Masters open, Michael and Julius used a bar like thing stuck onto the rear shock tower to avoid the body shell from being compressed during pitstop. Do you have a clearer pic of that? What parts are needed for that? Does it really work? Thanks.
* The pro brake pads, works good almost no wear but the steel brake plate seems to wear instead (but cheaper to replace). I use the pro plate with holes.
When using oneway front, I read that the best combo is the 9607 brake pads and the 9606 vented brake disc because it does not grab too hard. What about when just using solid front axle or front ball diff? Stock brake pads with 9606 vented brake disc?
Another tips (I have used it the last weeks) is to use a longer inner pin in the rear driveshafts (11.7mm instead of 9.7mm) as this decreases the wear of the rear diff steelparts. These pins was used in the S-705 and Impact differentials and seems to work, make sure they are perfectly centered though.
Anyway, just curious. Are the pins on the 705 rear dogbone (dogbone black in colour) the same quality as the pins in the Impact rear dogbone (dogbone Hudy brown in colour)?
Let's see...
You need:
Total: $282.97
Let's see...
You need:
Total: $282.97
Originally posted by Pyramid
all of those + belt tensioner bearings.. Indonesia price at USD150
No thrust bearing, only ball bearing for whole kit except steering saver ass'y..
