Like Tree3Likes
Tamiya TRF415
Old 05-23-2006, 01:19 PM
  #14236
tamiyarcracer's Avatar
Originally Posted by DOMOisCOOL
Can someone please give me the part numbers for the battery posts and the strap? Thanks in advance!
for which battery posts and strap?
tamiyarcracer is offline
Old 05-23-2006, 01:22 PM
  #14237
DOMOisCOOL's Avatar
I've heard some Schumacher ones fit and some Xray ones fit as well. Don't know which goes with which.
DOMOisCOOL is offline
Old 05-23-2006, 01:49 PM
  #14238
I know for sure that the X Ray battery hold down fits, it comes with everything
Part # 306163
Old 05-23-2006, 04:45 PM
  #14239
Mason's Avatar
i think 6163 is for the T2. I know for a fact the FK05 strap (306160) fits the Refine 2, just got to countersink some spots in the tape slots, and i'm about to mount it on the original 415. I dont know what the difference is between the two straps.
Mason is offline
Old 05-23-2006, 06:54 PM
  #14240
JRRobiso's Avatar
Originally Posted by Ollie RDX
That could be pssible but i saw a TA-05 SPool with delrin cubs in a shopt from tamiya! But hell what does it matters( allot i think becaus the delrin outdrives are much better) Steel outdrive aren't that direc ton the axle!
Greetings ollie
I currently use the 415 spool but with the TA05 steel cups & have no issues. It does chatter just a tad bit but not noticable on the track & doesn't hamper the performance of the drivetrain. It may be slightly heavier than the delrin cups but durability wise, the steel cups last longer especially during hard frontal impacts.
I'd prefer the 415 spool with the TA05 steel cups over the Speedtech spool (1st version) due to it's lighter than the latter but I keep the Speedtech spool in my toolbox just in case.
Just my 2 cents.
JRRobiso is offline
Old 05-23-2006, 09:53 PM
  #14241
Leester's Avatar
Trader Rating: 23 (96%+)
Hello guys.
does anybody know how to fit the TA05 gear pully's such as the diff, center one way and front one way on the 415? does anybody have any suggestions?
-Lee
Leester is offline
Old 05-23-2006, 10:02 PM
  #14242
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Leester
Hello guys.
-Lee
Lee
per Dan Garber's instructions in using the TA05 pulleys on the MSX. loosen the bulkheads, slide the front oneway or diff in... then slowly tighten down the bulkheads again using a star pattern. then secure the top portion using the same star pattern. its a snug fit, but it works.
- Chris
Hebiki is offline
Old 05-23-2006, 10:03 PM
  #14243
Hebiki's Avatar
Just my 2 cents.
Jun, how's it going buddy? i sent you a PM. appreciate your help!
Hebiki is offline
Old 05-23-2006, 10:07 PM
  #14244
Leester's Avatar
Originally Posted by Hebiki
Lee
- Chris
Yes but i'm talking about how to put the 415 diff and one way outdrives on the TA05 pullys and i'm stuck on how to do that
Leester is offline
Old 05-23-2006, 10:09 PM
  #14245
Hebiki's Avatar
oh my bad Lee...
the TA05 one way pulley will work on the 415 one way.. you will need to attach the pulley using one screw first.. then line up the other two.. although they dont line up perfectly, it will fit. attach the other two screws.. and tighten each screw slowly.... take turns tightening down each one..until they are all tight. from there you should have a 415 one way with the white TA05 pulley on it. hope that helps.
if you still need more help, let me know ill install it in mine..and take pictures. it might take some time though
- Chris
Hebiki is offline
Old 05-23-2006, 10:14 PM
  #14246
Leester's Avatar
Thank you!
what about the diff? any suggestions on that?
Leester is offline
Old 05-23-2006, 10:48 PM
  #14247
WRXTC's Avatar
Originally Posted by F. Alonso
These posts are actually the Aluminium Body Posts for a Tamiya F201. Pretty cool idea actually. He uses them on his MSX now. With the Schumacher brace, you may need to mill it slightly so that it doesn't rub on the cells as they are quite fat posts from memory and I think I remember seeing others who have had to do that.
I installed the battery posts and brace. With 3300's it's a tight fit but they fit with no milling and the cells don't look like they would fall out in a hurry. Maybe with 3800 or 3700's I would have to mill out the posts a little. Just the purple blue bling clash hurts my freaking eyes....
WRXTC is offline
Old 05-23-2006, 11:08 PM
  #14248
JRRobiso's Avatar
PM back @ you
JRRobiso is offline
Old 05-23-2006, 11:22 PM
  #14249
Stein Tumert's Avatar
Lee
- Chris
The rear TA05 diff you can built straight up witht the MSX alu diff parts.
For the front TA05 one way, we shave off a bit material as it is thicker in the center part as the MSX one way pully. We have taken off about 4/10 of a mm in a lathe on each side. Then it fits about the same as the MSX pully between the bulkheads.
Stein
Stein Tumert is offline
Old 05-24-2006, 12:32 AM
  #14250
DOMOisCOOL's Avatar
Hi all, I just came back from my first race with the TRF415. The handling was awesome. This car is very predictable with my setup.
However I encountered one thing. While going down the back straight I accidentally clipped the board and bent/snapped the right front aluminum steering turnbuckle. This part seems rather weak, considering I didn't even go head-on. I just brushed the board.
Are there any aftermarket titanium turnbuckles or do I have to get the Tamiya ones?
