Tamiya TRF415
hi guys
hi fellas',.. im have my trf 415 for the 1st time.. im planning about to use it on tamiya super modified 11t... what is the recommended pinion and gear for that...? i want top acceleration and full speed. tnx...
For 11T motor, use 27T pinion should be good.
Originally Posted by TryHard
Removing or adding shims there affects your bump steer... removing shims, I believe, gives you less (as the link angles downwards). Adding shimswould give you more (as the link is added upwards).
HOWEVER... it is generally best to run zero bumpsteer (ie a level link), it can make the car difficult to drive
HiH
Ed
HiH
Ed
The first will make your car turn in sharp off power, and loose steering mid corner, the second will make the car easier off power but give more steering mid corner. Don't change it too much as only 2mm can make your car undriveable (as i found out recently). Also don't forget that it's affected by how many shims you run under your blocks, but also by how angled and how long is your upper link.
Oneways
Hey, i got a 415 not too long ago and it came with a diff and a 1 way, because i race carpet, and i used to use a diff, i just put it in and raced once. Now, i was thinking i would try the 1 way just for fun, but when i put it in it jammed up my steering and the 1 way bearind didn't work(left side, the cup has a little added bump to make it wider). I find this odd because it works perfectly out of the car. I was wondering if any of you ran the 1 way on carpet, or does it give you too much steering and make the car too hard to drive. I've never used one and i was just wondering if it was worth using after i get it to work?
PS, did i make some stupid mistake because i don't have a manual and put the diff in backwards or something like that?
Any special attention or tips before I build my msx ?
-Thank TRF415boy and TryHard
Charles
Be sure to check that the bearing isn't the other way round. If installed correctly,both your front wheels should spinning freely forwards.
Cheer...
New hopup for the LWS.
Tamiya TRF415 5x1.9mm Bearing Spacer
how much is he 415msx conversion kit for the tamiya 415ms
Originally Posted by Jack2
t4m1y4niac,
I am sure you can just about order from any country. So the answer to your question would be - Yes
Originally Posted by Eirik
Hello,
Up Front: Shorter link = less steering and more stable going inn to corners!!
Rear: Shorter link = more High Speed steering and more stabillity, "Less Grip"
Rear: Longer link = More turn inn, more traction, but less stabillity!!
This is more or less what you will feel when you make this changes....
I don't quite get it when he means more stability but less grip, and more traction but less stability
asw7576,
With less grip and more stabillity I mean that when the car starts to slide it's much easier to controll the slide!
Longer link will give more traction to a certain point where it will break loose more abrupt....
Kind of hard to explain, so you better try it on your car and then you will fully understand what I mean
asw7576,
I think I copy the marc rheinard's setup for asphalt and have fun with it. ( That's why tamiya paid him right ? )
