Tamiya TRF415
#8806
Tech Legend
Trader Rating: 51 (100%+)
Originally posted by jeffreylin
Just a FYI, Tamiya yellow 400 included in the kit is closer to 30wt.
#8807
Originally posted by wyd
I might do 40wt with 3 holes that way I will have a good comparison if I use the same oil but different piston. I might get a better feeling that way.
#8808
Tech Legend
Originally posted by Burlap
I'm using 40wt Schumaker oil with two holes. I found the car to handle nicely with it. Maybe it is a mind over matter thing since I always ran two hole pistons in other chassises.
#8810
Tech Legend
Well I think it is a great idea to try it. Its that or I just have a new set of tamiya shocks sitting around doing nothing.
#8811
Originally posted by F. Alonso ATM I'm using 30wt oil with 3 hole pistons front + rear and the car seems to handle the bumps at our track pretty well. I have another set of shocks that I'm going to have different so we'll see how that goes.
#8813
Re: Oil weights
Originally posted by Ill Factor
I run on medium grip asphalt and run 2 holes in front wht 35wt & 2 holes in rear with 40. Car really digs in on the corners and Chicanes. I am easily the fastest in and out of turns at our track. I am also using yellows front and rear with read stabilizers front and rear. I have abother set of srpings on order and plan on trying softer spring with thicker oil to see what kind of action I get. Right now the car is dialed as hell.
Eirik, have you guys experimented with a center oneway and a front dif? I have been using this setup for a few weeks and the car is much more predictable.
I think a diff up front will be too slow in most situations, it will make the car super stable though! But it might be a good thing on some tracks I guess....
#8815
YGPM
#8816
#8817
Originally posted by ttso
Tamiya spool!
http://www.teamjoybox.com/shs05/shs05273.jpg
Source: http://www.teamjoybox.com/shs05/shs2005_index.html
Tamiya spool!
#8818
Diff
If you run a diff up front and leave the middle oneway the front wheels still free wheel, just not as long. The car has actually become faster do to the extra stabilty in and out of corners. I cant see how a spool would be any better. Are you guys running the spool with a locked center pully or the oneway center pully?
#8819
Ill - The Spool might not be better into or in the middle of the corner, but it should be far better on corner exit. The diff will allow one wheel to spin, not giving you as much traction. Spool acts like a one way on power.
If you have your diff tight enough, it won't allow the inside wheel to spin, but then it's acting more like a spool everywhere else.
On that Tamiya spool, I don't know why they used the Delrin outdrives. From what I've seen, they wear out in less than half the time of the black outdrives, and that's on a diff. I'm sure the spool will be much harder on the outdrives. Maybe they will be cheap, unlike the delrin diff outdrives, but I doubt it.
Mike
Mike
#8820
Re: Diff
With a diff up front you will have problems with spinning of the inside front tire coming out of corners, atleast I had that problem last time I tried. The car was super easy to drive so if the track is tricky it will work good I guess....
With a spool you have maximum drive from both front wheels and I feel that I can accelerate much sooner with that setup. I can also let off the trotle a litle later going into the corners and even break hard if I have too!!
I always use the locked centerpuley when I use a spool...
