Tamiya TRF415
#1606
Hi Jason. I think it's more the 2nd level decks than the top deck holding the chassis flat. The top deck is not very stiff and I think the benefit of countersinking that would be limited. There are also very little room you have around some of the screw holes for countersinking.
#1608
10X1 by REDLINE Motors.
#1609
counter sink
I have noticed the middecks have some play. I noticed the front deck was ofset after I built it. You could see more of a gap in relation to the bulkead and the camber mount. I centered it but I'm not sure if this would be easily tweaked.....I'll give it a try this weekend though.
#1610
Picture of my 415.
#1611
Another.
#1612
...another.
#1613
...one more.
#1614
Need some help my 415 is great inside just does everything i want but i went outside today testing and no matter what i do or change the front end in the middle of the corner and exit just pushes wide and will not hold the line on or off power. What shud i try changing to make the difference? Thanks Rick
#1616
From my experience the most important thing is to use the right tire compound and insert.
Now your problem is pushes wide in the middle and exit the corner.So, try this(step by step)
- use the softer spring in front
- take front anti rool bar off
- use the inner hole front shock position
(the more shock angle,the softer suspension)
- use stiffer spring in rear
- add more caster angle
- add the shim,spacer under the front suspension block to angle the front wishbone(kick up angle)
I hope this can help you
ohh!! suradej
I've seen many japanese driver use that black tube in the TITC race
what is that black tube on the battery cable for?
and is it called ferrite?
ohh!! suradej
#1617
Hey racers, does the 415 come with everything shown in the pics from the USA website? Aluminum rear hubs?
What about a front diff one-way, does that come with the kit? Also, does it come with a layshaft one-way?
Last but not least, does the kit come with titanium screws?
#1618
415 Push
Hi Rick,
More caster will help. Try the TA04 8 degree caster blocks.
Also, you could try reducing the front up-travel, thus preventing too much weight from being transferred to the rear under acceleration.
Martin Crisp
Martin Crisp
#1619
Originally posted by Holmenkollen
TRF team in Europe, trainig for the upcoming LRP Masters.
New chassi spotted on Surikarn`s car.
www.rcworld.ch
www.rcworld.ch
Even very few drivers are using double upper decks. I have only seen Surikarn and Maezumi using the double. At one picture in this thread the lower of the double deck plates looks silver colour like aluminium or SSG. But from a closer look this is an optical illusion maybe caused by the digicams lightning (?). Infact itīs a slightly brighter graphite upper plate maybe from a different batch.
#1620
