Ko BMC Speedo
Old 01-25-2010, 11:32 AM
  #946
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Alex C
I must say from the photos provided that track looks awsome !!!
I haven't been there. But mark and the guys responsible for it built timezone up in washington. Its a 1/5th scale track that's freegin ridiculous. So I ordered myself a T3 and when the new batch comes in I will build it in about 2 hours and go racing lol. Their carpet track is the largest I have heard of. That's the size of most parking lot tracks lol
So any ideas on a starting gearing? I haven't run my BMC's in version 1.5 yet. So I will be starting from scratch.
rx7ttlm is offline
Old 01-25-2010, 01:07 PM
  #947
Johnny Wishbone's Avatar
13.5 start at 4.4 to 4.6 FDR. The 17.5 start at 4.8 to 5.0, watch for temps at 3 minutes, 1 fan on motor, and readjust for heat. Goops profile on timing 6 and adjust for punch. The pulse could be a bit of a challenge for gearing, really watch your temps on that motor.
Johnny Wishbone is offline
Old 01-25-2010, 01:14 PM
  #948
rx7ttlm's Avatar
you sure you dont have those ratios backwards? lol
rx7ttlm is offline
Old 01-25-2010, 03:47 PM
  #949
Trader Rating: 8 (90%+)
is it nessasary to run the fan on the speedo for 17.5, I would not think so because it is just a stock class. I have the worlds cooling kit on it now
I am running the v1.5
Tha Skinny is offline
Old 01-25-2010, 04:05 PM
  #950
buffalobill989's Avatar
Trader Rating: 50 (100%+)
you dont need it it just looks cool
buffalobill989 is offline
Old 01-25-2010, 04:06 PM
  #951
rx7ttlm's Avatar
I know you need it running 10.5 and 13.5. Not sure about 17.5 as I haven't run that class yet.
rx7ttlm is offline
Old 01-25-2010, 07:09 PM
  #952
Alex C's Avatar
Originally Posted by Carl Giordano
Thanks Alex....not sure what yo mean by Profile #1? Do you mean the default setting on the v1.5? I did not see an attachement?
Carl,
My apologies.......the file failed to upload, please see the attached txt file.
Please note as mentioned make sure to check your temp at the four minute mark just to make sure.
Try it out tell me what you think ...............Best Regards!!!
File Type: txt
Alex C is offline
Old 01-25-2010, 10:04 PM
  #953
rx7ttlm's Avatar
Carl,
Hey alex, you have a newer version of what drew or anyone else runs in tc?
rx7ttlm is offline
Old 01-26-2010, 12:22 PM
  #954
Most of the guys use the fan and have it pointed towards the motor. The tap off the sc is direct to the batteries so the fans really scream and work very well for motor cooling, plus it makes for a much neater install, wires wise. You really don't need it from 13.5 up, haven't had any heat issues yet.
The gearing might be backwards. At the IIC the 17.5 ran a 3.8 fdr on a SPV3, and its sort of like a pulse, but if I where running a pulse I would change out the rotor to one of the torque units and play with gearing from there, this really woke up my pulse, the rotor in them just dosen't feel right at least for the tracks I've run on.
Old 01-26-2010, 01:58 PM
  #955
rx7ttlm's Avatar
ok, no worries. Working on getting other motors anyhow. I usually don't run spec classes but the most competitive regional racing seems to be the spec classes lol.
rx7ttlm is offline
Old 01-26-2010, 02:11 PM
  #956
so I will run practice tonight and play with some gearing. Someone direct me to a couple of esc setups and I will play around and see what I can come up with. I run a Novak 17.5 in TC on carpet. The track is 75x45. I will let you know....
Old 01-26-2010, 02:13 PM
  #957
seaball's Avatar
now THAT is what a tc track should look like...
seaball is offline
Old 01-26-2010, 02:14 PM
  #958
rx7ttlm's Avatar
Yeah, I can't wait to get my T3 and go test. Its Fing SICK lol
rx7ttlm is offline
Old 01-26-2010, 02:30 PM
  #959
I need esc set ups
Old 01-26-2010, 03:27 PM
  #960
Alex C's Avatar
Smile
Unfortunately I do not since I mainly run 1/12 Scale 13.5, although I would look back a few pages and see if my Bud Goop had posted anything!!!
Best Regards!!!
Alex
Alex C is offline
