losi lipo balancing
Try Max Amps, they will custom make one.
Metalracer2, I have the same issue (Losi 7.4v 30c 4400 Lipo) and Hyperion 0606i. You stated in your response above, that you contacted MaxAmps and ordered a conversion cable to connect the Losi Lipo to the Hyperion. I called Maxamps this morning to order what you did, but they knew nothing about it and stated that Losi is one of a very few Lipos that the Hyperion doesn't work with.
My questions to you are: (1) did what you order work?; (2) if it did work, what did you order so I can order it too.; (3) if it didn't did you find a resolution? After my call to MaxAmps this morning, they suggested that I ask you the above questions and if the end result was positive, then they may be able to duplicate.
Thanks,
David (aka Fuzewolf)
Thanks,
Thanks,
Thanks,
http://www.maxamps.com/TP2S-HYP-Adapter.htm
or u can try the link rcgaryk posted
Thank you both, RCGaryK & Metalracer2. I thought the Losi harness from Horizon may work, but for the price of the MaxAmps, I'll go with it. Which adapter are you using? The TP or what? Sorry, I should have asked this question with the original. I have the adapter that was included with the Hyperion and purchased the LB10TP.
Thanks again everyone.
