XRAY T2’009
Old 10-10-2009, 08:21 AM
  #1951
R1wurks's Avatar
one more thing, is there ceramic thrust bearings available for 009? is there ceramic diff balls available?
R1wurks is offline
Old 10-10-2009, 08:31 AM
  #1952
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by R1wurks
how long does your diff and thrust bearing last before you have to sand down & rebuild your diff on a T2 009.
any help would be greatly appreciated.
I think the answer is, it depends. In my T2'008 EU I've never even opened the rear diff because I primarily run 17.5T in that car. In my T2'009 EU with a 13.5T I've rebuilt the diff a few times in the past few months as it has gotten gritty.
Paul LeMieux gave a bunch of us a diff building clinic at the Asphalt Nats last weekend. He suggests cleaning/rebuilding your diff often -- as frequent as every 4 runs. I know that I cannot feel on the track the difference between a new diff, and a diff with 10 runs but I'm sure Paul can. He said that he replaces the trust bearing much more frequently (7 to 1) than the diff rings/balls.
On the following page Paul describes how he builds a diff (scroll down a bit, or look for 1000): http://forum.teamxray.com/viewtopic....&start=140#top
hanulec is offline
Old 10-10-2009, 08:32 AM
  #1953
hanulec's Avatar
if you search online you will find a few aftermarket ceramic thrust bearings. i cannot say how good they are as i haven't tried any yet. i think it is best to just replace the thrust bearings when your diff starts to feel weird.
hanulec is offline
Old 10-10-2009, 08:57 AM
  #1954
KHoff7's Avatar
I can second that. Ive rebuilt one of my diffs time and time again and it always felt notchy. I tried the thrust bearing off of my good diff and it make my "bad" diff fell perfect.
KHoff7 is offline
Old 10-10-2009, 10:08 AM
  #1955
Regional Moderator
CarbonJoe's Avatar
Generic Ceramic diff balls here:
http://rc4less.com/Bearings_&_Diff_B...duct_info.html
The stock Xray ones are 2.4mm (0.094) and the 3/32 ones at rc4less are 3/32 (0.093)
Ashford Hobby has the Xray carbide ones: http://ashfordhobby.com/detail.aspx?ID=4311
as does Nexus Racing: http://www.nexusracing.com/product_i...roducts_id=294
and AMain: http://www.amainhobbies.com/product_...ifferential-12
The Xray ceramic thrust bearing is $28!
http://www.amainhobbies.com/product_...ing-Axial-F3-8
Does anyone know of another source for the thrust bearing, probably from another car? The size is 3x8x3.5mm
CarbonJoe is offline
Old 10-10-2009, 10:24 AM
  #1956
This is what I run:
http://www.axiommotors.com/thrust-be...c-113_164.html
Kody is offline
Old 10-10-2009, 10:33 AM
  #1957
ngo8's Avatar
Originally Posted by Kody
This is one i am looking at not sure if it will work
http://www.rc-mushroom.com/product_i...ducts_id=18845
ngo8 is offline
Old 10-10-2009, 10:57 AM
  #1958
johndayo101's Avatar
Trader Rating: 128 (100%+)
Default ceramic
steve i use the ceramic balls from axiommotors.com and it wurks! i just pop the balls from the thrust and replace it with ceramic. you can us also use there thrust bearing but use the old plate. the but if you need the original XRAY Carbide 3x8x3.5mm Ball Bearing Axial F3-8 i have brand new in a pack 15 shipped.:
these are the sizes
1 x 2.4mm Ceramic Balls (12pk) $10.95
1 x 1/16 Ceramic Balls (8pk.) $4.95
johndayo101 is offline
Old 10-10-2009, 05:04 PM
  #1959
gonzo416's Avatar
Trader Rating: 39 (98%+)
Would these work? http://www.amainhobbies.com/product_...st-Bearing-Set
If so what rings can be used in replacement of the old ones?
gonzo416 is offline
Old 10-10-2009, 05:55 PM
  #1960
hanulec's Avatar
losa3018 should work. avidrc has a thrust for $3 too.
I've only run the xray thrusts and diff rings/balls to date.
hanulec is offline
Old 10-11-2009, 05:28 AM
  #1961
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
i asked RD what he does slot the 1 chassis servo hole (he slots it), but does any1 else in xray camp use a 9551 futaba? the fit isnt that great isnt it. is a 8800 a better fit? slot the chassis? thoughts. thx
R
UltegraSTI is offline
Old 10-11-2009, 09:07 AM
  #1962
R1wurks's Avatar
thanks hanulec! R1wurks is currently working on a project aimed at making diffs last longer. your input is definitely appreciated!
R1wurks is offline
Old 10-11-2009, 09:21 AM
  #1963
R1wurks's Avatar
thanks again hanulec! we are just trying to see whats out there as we are new to xray cars. we actually have 2.4mm 3/32" diffs balls for the 009, its available at speedtechrc.net $7.99 per pack of 12 http://www.speedtechrc.com/store/ebp...?catmainid=689
this diff balls are very high quality & they are hand picked, measured & matched per pack to achieve optimal performance
we will also have balls for thrust bearings next week.
R1wurks is offline
Old 10-11-2009, 09:32 AM
  #1964
R1wurks's Avatar
thanks KHoff! your input is appreciated.
these are the sizes
thanks carbon joe, kody, ngo8,johndayo101! we are just trying to see whats out there as we are new to xray cars. we actually have 2.4mm 3/32" diffs balls for the 009, its available at speedtechrc.net $7.99 per pack of 12 http://www.speedtechrc.com/store/ebp...?catmainid=689
i heard xray rings are pretty good, R1wurks is currently working on a better diff ring to improve currently available diff performance.
R1wurks is offline
Old 10-11-2009, 10:33 AM
  #1965
sm1nts2escape's Avatar
Trader Rating: 16 (100%+)
Who has tried the xray 38t conversion?How did it change the car?Thinking about purchasing it today.Thanks
sm1nts2escape is offline
