eZRUN brushless system
#241
I have the 35A ESC with the 3000kv motor, love it and it is very fast in my GV2 buggy. However my switch fell apart before the main, I managed to get the little sucker back together and win the final. My question is, can it be replace with a generic micro switch? When it was apart it looked to have some type of circuitry in it besides being a switch?
#242
novak
to answer the question about a Novak brushless with the Ezrun. I use a Novak motor in my XXX-T with the Tekmodel Hobbywing 60A esc and have had no problems at all such as cogging. I am very happy with the combo and it seems very fast and alot more efficient than my brushed 19T motor with Novak esc.
#248
#250
So can someone answer my question? Can a regular micro switch be used and has anyone actually done it?
#252
#253
Hello guys, i am new as you can see and i wanted to share my experience with ez-run combo with you.
I own an ez-run 35a+9t combo and until now i had it installed on a 1:10 scale street car with amazing results.
My setup was a 200mah 3cell lipo (changed the cooling fan of the esc to a 12v fan) and it was very fast with 10-12mins of playtime.
One week ago i bought a used Kyosho Dbx nitro and i decided to convert it to brushless.
So i removed the brushless ez-run setup from my 1:10 street car and installed it on the Dbx.
So, here i have an issue.
After 6 mins of play the esc gets too hot and the temp sensor kicks in and it cuts off.
Can you please suggest me what to do?
Should i move on a 60A esc? Or maybe 100A?
Btw the kyosho dbx in brushless 9t is much much faster than the stock nitro gxr18 engine...
But the esc overheats...
I would really appreciate any of your help.
#254
Thanks Scottwhat, wanted to know before I started cutting wires!
George I would say look into the 60amp I would bet that car is a bit heaver and the motor is working harder and heating the speedo up. Also if you want to sell the 35amp, let me know!
#255
R/C Tech Elite Member
The Nitro is too big mate
These Ezyrun are fine in a touring car, 2wd buggy even a 4wd buggy at a pinch but will burn up in a 1:8 conversion, monster truck, even a Traxxas Slash is too big for it to haul around for longer than 4-5 minutes
