eZRUN brushless system
#151
Use really good quality connectors and make extentions so that you can move your esc somewhere else? Since this is a budget system, and expectations should not be the same as a $300 system.. the loss you suffer from extra connectors could not be any worse than using a tamiya plug in a car!!
#152
NEWB QUESTION
I am new to on road
and brushless third setup ...
Whats max KVs on a 540 BL motor that I can run on a 3s LiPo safely with the
60A EzRun?
Thanks! ! ! Alex
I am new to on road
60A EzRun?
Thanks! ! ! Alex
#153
HI - COLOUR not good - that LIME was almost impossible to see!
A 3s lipo is 11.1v - You will have to change the fan which if you are going to do lots of power - you dont want to have no fan. The 60A on most sites is rated as their 5.5t or above the KV of the 5.5t is 6000kv
#154
How much is the height of the ESC without a fan, someone could measure that?
#156
if you're running 3s lipo I'd say just patch the fan cable into the BEC, or onto a spare receiver port.
#157
I didn't realize that green was so bad sorry , thanks Bikerbob and that means I am safe to use a 5900KV 540 can as long as the original fan is connected to a bec? Or you mean I have to change the fan ???
#159
#160
hey guys ive just gotten my ezrun 5.5t combo and im having some trouble setting it up
ive tried following the instructios but they are a bit vague .
my problem is that my car is running in reverse and ive checked and my controller isnt set in reverse. i think im having the trouble with when u have to setup the throttle spots . im not sure which spot your meant to hold it on what beep, does any 1 mind explaining to me really quickly please
thank you
thank you
#161
If all else fails, read the instructions
It says in the instructions if the motor runs in reverse swap two of the wires over.
If taht fails, read the instructions again !!!!
And vlozity .. your first measurement of 25cm or 250mm that you edited was far more entertaining
#162
yea i read through the instructions but it definetly just confused me lol. this is my first brush less motor so im not sure which wire doest what. ill attach a photo with how ive soldered my wires and you guys can see if i have done something wrong .
just some trying to show how ive soldered it up. and 1 or 2 showing the sex machine :P
#164
argh soz about being a retard . had a big night last night and my heads still out of it from the tequila lol .
i worked it out now and got it going forward properly . but i still have a problem when i pick it up and just let the wheels spin freely in the air it absolutely flys but once i put it on the ground it either doesnt move or it just jutters along . is it something wrong with 1 of the esc settins like with the program card? any help would be nice
#165
