Rc10ntc3
#4891
Okay, I leaned the engine and shortened the fuel line. The car still does the same thing. How often do you usually replace the two-speed shoes? I've never replaced mine and I've owned the car for a little over a year. If you think it's horsepower that's causing my problem, I've got a heavily modified ROAR legal motor (Murnan modified Novamega 2103 RMS) I can put in it, and/or try some 30%. bbntc3, where do you have your tubing routed? My fuel tubing goes between the engine and pipe. Should it go the long way around over the throttle servo to the other side? Do you have any pics of your car that I could model mine after?
Thanks!
Thanks!
#4892
Originally posted by SpeedyOB-4
Any info would be appreciated!
Thanks!
Thanks!
#4893
Okay, I did that too. I took the two-speed out and cleaned it. It still did the same thing. So, I went to a smaller range of gears(the stock setup). It still did it. Maybe this is how it's supposed to sound. Does your guys NTC3's shift hard? I've got soo much horsepower that my wheels spin for a while. When I gradually accelerate, the shift is smooth, but when I give it full throttle immediately, the shift is hard. The rpm's shoot up, then it grabs the second gear and takes off. Maybe I'm just not getting enough traction, and therefore spinning the tires when it shifts causing the RPM's to stutter because the car is regaining traction. I don't know, just a thought. Thank you to everyone who's helped out!
#4894
Registered User
Heres some pics
#4895
Registered User
another
#4896
what kind of swing arm is that bb?
#4897
Registered User
That's the K-Factory steering rack assy. Remove 2 screws and the ball sockets and it all can be removed.
#4898
I recently took my NTC3 totally apart and the chassis (the original one from the kit) is badly tweaked. I am thinking of getting an after-market chassis and want to know what people think about some of them, or which they think is the best quality:
¥K-factory
¥Golden Horizons
¥3Racing
¥RD Logic
¥Zero Gravity
¥GPM
or another I haven't listed. Which is strongest, lightest etc....
¥K-factory
¥Golden Horizons
¥3Racing
¥RD Logic
¥Zero Gravity
¥GPM
#4899
Registered User
BMI CHASSIS!!!! Best on the market at present time!
#4900
Regional Moderator
Originally posted by Ataman
I have try already on my son's RS4 for about 2 gallons-works great, and I stop paying for new tanks and most importanly-before, every time we came to practice-we paid entry fee, but after tank blew up , we got to go home with no practice-was sucks. Actualy, the stock tank doesn't have anything to reduce vibration too, not even flex mounts.
Jon
#4901
Registered User
Even though the Ae tank mounts with o'ring it's really not isolated, it only has a single set of 3 screws bolting it to the chassis. leaving it loose sorta helps but its no cure, The fuel vibration problem is more due from the too much material removed in the engine pullstart area.
#4902
Regional Moderator
#4903
Has anyone here tried the zero racing chassis? I have one on my NTC3 and it seems to work well, but I'd like to know the next step up. The BMI chassis is a bit too much for my budget...unless it'll fix all my problems. If it'll take the slop out of my steering, the vibration out of my tank, etc, it might be worth considering. However, I don't think a chassis can address all of the problems my NTC3 has. I don't need a crash resistant chasssis, I need the best chassis for racing ROAR events. Should I just stick the stock one back on?
What have you guys done to take the slop out of all the ball cups, pivotballs, and hinge pins. There's not a whole lot of slop in each one, but when they're all combined the performance is reduced.
#4905
Chassis and K Factory replies
I dont think you can beat a stock chassis. Not to say that there arent nicer ones but the stock will get the job done and it doesnt cost any extra. I have owned a few different chassis and finally came to that conclusion.
As fas as the K Factory swing rack....what a over priced peice of equipment. It does not reduce any slop no matter what people claim. Its just hard to admit it once youve spent $40+ for something that doesnt do anything other than making it easy to remove. That has its advantage but it is not worth it and you would think they would do something about the increasing the distance between the drive cup and the swing rack arm. After all my K Factory stuff I have bought I am left wondering was anything I bought good? I dont think so....it was a good and exspensive learning experience but unless you are going for the BLING BLING factor I cannot reccomend K Factory.
