Rc10ntc3
#2266
well how did ntc3 nut get both sets for $80??
i'm only interested in the diff cases and chasis braces...
is it $20 for EACH case? or for a set of 2?
#2267
HI! I just want to know where did you guy go and find product on the NTC3 on the Rdlogics site? Thanx!
#2268
Originally posted by torchedlh
i gotta check something with you guys...
persepective is from the back of the car:
the engine's flywheel/clutch shoes run CCW
the spur gear and main dirve shaft run CW
i'm just really confused, becaues right now my starter box wheel spins CCW, however i never had a problem with my FE running backwards, and i can't imagine that i chagned the polarity of any of the connections...
please help me out guys, i'm confused.
That confused me too. What ever way you set the car down on the box, the starter wheel should spin the opposite direction that the engine spins.
#2269
well i figured it out... i had the starter box wheel spining the wrong way. i'm very confused as to how it got that way because i've been using my FE forever with the box fine. so i guess sometime between getting rid of my FE and getting my CV-R, i musta switched the polarity of the connections somehow. anyway, it's setup perfect now and today i started to break in my CV-R.
#2271
the only NTC3 part that Steve carries is the RD Logic Chasis. he doens't have any of the diff cases, chasis braces, or shock towers.
#2273
why would you want a carbon fiber shat? the stock ones hols up fine, i've never had ANY problems with it. If you want a pretty looking shaft, you can get a AE factory team one which is anodized blue....
#2274
Registered User
I thought about carbon fiber driveshafts, but had 1/4 " Titanium rod laying around, so I made my shafts Titanium!
#2275
I would imagine that carbon driveshafts would shatter or snap from torque when you suddenly hit the gas/brakes or if you bump anything.
#2276
i emailed RD Logics and for $70 you get:
4 diff cases
2 shock towers
4 chasis braces
AND the RD logic chasis..
sounds like a damn good deal to me, but i'm only interestd in the diff cases and chasis braces. here are the individual prices:
diff cases: $20
shock towers: $20
4 diff cases
2 shock towers
4 chasis braces
diff cases: $20
shock towers: $20
#2277
Registered User
When the electric TC3 came out I got on the band wagon bought a Trinity Nitro Conversion Kit. I done the conversion and raced a 190mm nitro TC3 for 2 full seasons. I bent 3 alum shafts in that time, but always fell back to the carbon stock AE shaft. It never give me any troubles at all, which I thought was strange because I have seen electric TC3's twist the carbon shafts into pieces.
#2278
yeah i got my RD Logics Ntc3 alloy combo in blue on order
should be here in a week
i wouldnt think that u would need to shim the diffcases because they where moulded from the plastick ones hey ????
but i ordered the shim kit from ae
enybody eva snaped a socket cap ???
i did on my vitory lap (couldnt here that the race was over and went for a hot lap) for the 10 min a main i kida wend sideways into a pole and all it did was snap the socket cap, i thought the toe link would of been gorne for shure but it wasent that was the only think that happened oooooo it also bent the manfold but that straightend right back
ahhhhhh well i still won
#2279
Registered User
All that for $70? man that's very cheap! I'll bet the shocktowers bends very easy. Most good deals are usually too good to be true! 6061 Alum is light but kinda soft.
#2280
ahhhhhhhhhhhhhhhhhhhhhh now u tell us once i ordered it
it will be good it better be good if it aint ill
