Like Tree3Likes
Rc10ntc3
Old 02-04-2003, 05:13 PM
  #2281
Francis M.'s Avatar
bbntc3 you will probably end up breaking the screw before
you bend the shock tower.
Francis M. is offline
Old 02-04-2003, 05:29 PM
  #2282
Brett's Avatar
sweet
didnt think it would be crappy
Brett is offline
Old 02-04-2003, 07:17 PM
  #2283
Registered User
Smile
For some reason I find that hard to believe! I'd go ahead and pay the extra dollars for the Lifetime replacement option that RD has, You'll need it! BB
bbntc3 is offline
Old 02-04-2003, 09:44 PM
  #2284
theRED5's Avatar
Sorry for the late posts, I'm trying to get ready for the WinterNats... I think if your only gonna use on half of the diff cases, you'd be better off using the BOTTOM half....the long bolts that fix the problem with the shock towers goes all the way through the top half of the diff case, and screws into the bottom 1/2....Besides this is added weight that should(is) be looked at as strengthening weight.. when I get my sets I'm using both.
theRED5 is offline
Old 02-04-2003, 10:03 PM
  #2285
superk's Avatar
Well...will this set help on car handling? is it going to be ligher than stock?? any one run the car wth the whole set on it yet?? I like to get one myself!! looks really cool!!
I mean...how is it going to effect the car setup and handeling??
superk is offline
Old 02-04-2003, 10:25 PM
  #2286
Francis M.'s Avatar
the diff case when used as a set should give you a
more rigid suspension. the way ae desinged the car
the whole suspension component is connected to
the diff case. as for weight it will weigh a little more
if you are serios about racing just use the diff cases
as it will secure the towers enough to the point that
the only distortion in the suspension would be within
the shock arms. any way if you use the AE hard anodized
or the new rd logics hard anodized chasis you will
feel the car always run more consistent tweak wise
with the aluminum diffs. I don't recomend using the
optional aluminum screws use the sleele screws to attache
the diff cases and to secure the shock tower weather you
decide to use the stock or aluminum tower.
Old 02-04-2003, 11:05 PM
  #2287
Striker's Avatar
jwf_frani:
Do you work for RD Logics? If so, when ording the Nitro TC3 Die Casting Aluminum Set, there is not an chance to add the free replacement option. Is this not availible with this set, or has the websight not been updated yet? Thanks.
Striker is offline
Old 02-05-2003, 09:32 AM
  #2288
Francis M.'s Avatar
striker i only drive for them and I don't have
too much details on the replacment guaranties
or pricing except for what I see the local
dealers sell it for in socal
Old 02-05-2003, 11:16 AM
  #2289
Default pics
where can i see some pics of these rd parts ?
thanks, Dean
deanspoors is offline
Old 02-05-2003, 11:39 AM
  #2290
Francis M.'s Avatar
go to page 76 ntc3nut has an attachment
with good pics.
Old 02-05-2003, 12:10 PM
  #2291
Team Driver
Originally posted by Striker
jwf_frani:
The liftime warranty option will be available on site Tonight.
Thank You
RDLogics is offline
Old 02-05-2003, 12:32 PM
  #2292
Team Driver
jwf_frani:
Replacement option plan is availble now. It only cost $10 more, you can have lifetime replacement option.
RDLogics is offline
Old 02-05-2003, 03:05 PM
  #2293
theRED5's Avatar
Now that's what I call customer service....
theRED5 is offline
Old 02-05-2003, 03:32 PM
  #2294
ilaybrk's Avatar
rd logic shop owner I ordered 2 sets of ntc3 die cast alumnium set and I wanted to ad the lifetime replacement that is now availible two days later
ilaybrk is offline
Old 02-05-2003, 03:57 PM
  #2295
NItRO PuPS's Avatar
Wow great deal, I might look into this since i'm thinking about replacing my chassis, is the chassis covered under the replacement? since its part of the die-cast set.
NItRO PuPS is offline
