TAMIYA F103 RM
#1441
MP4-23
form HK customer was made 1 month
TRG type M body
Tech Rear Wing
http://rcmarket.com.hk/index.php?cPath=68_213
TRG type M body
Tech Rear Wing
#1442
So what is the type C body? Is it going to be a group C shell or are they releasing another F1 body? I just got a 103R and I need a body for TCS, but I'm not that excited about the M-type. And I'm not going to shell out $60+ for a body off ebay that I'm going to abuse racing.
#1443
I wonder when will Tamiya bring back their rear diffuser....
#1444
Are these the S Parts previously mentioned?
Thanks!
#1446
#1448
Hey guys.
I just got a few parts for my F103R.
I ordered the high downforce front and rear wing set from 3Racing and I also got the TRG carbon print rear diffuser.
I mounted the wings fine, but I have a question...what body can I run with this set of wings? Does it matter or will any F1 body fit it?
Next....the diffuser. Does this mount underneath the chassis or between the chassis and motor mount? It seems to be too wide and hits the tires a bit. Should I trim it down or I am doing something wrong?
Any help would be great!
#1449
Hey guys.
The Diffuser goes in between the motor mount and chassis. Yes you might have to trim the diffuser down a bit. I had to with my one.
hope that helps.
#1450
Hey guys.
the other option is to mount it below the tbar so you have a flat chassis bottom. i put mine so its like the best of both worlds.
see here:
side view
below view. if you look closely, you can see the bend. its only about a 1/2-3/4 inch flap.
the splatter is a little bit of grease i use on the gears to keep them a little quieter. as far as rubbing against the tires, mine doesnt. (atleast not on the 1/10 26mm wheels used ont he f103GT. once my f103lm diff parts come in, ill let you know if i got any rubbing.
i reccomend shaving a little off if you rub, or you can just scoot the diffuse forward a little.
#1451
Thanks for the pics.
Did you cut yours at all from side to side? It seems to be too wide and it rubs the tires a little. Should I cut it down a little?
Motor cooling isnt a matter of concern, I wont be running my F103R, but thanks for the advice. I might put a diffuser on the F1 that I do run.
I think I will mount it in between the motor mount and T-bar also, so I can keep the countersunk screws there.
#1452
i reccomend you mount between the t bar and motor mount.
which one you end up getting? i got one from TRG that causes the air to leave straight, not flowing upwards.
any one used both? which do you prefer and why?
#1453
no side to side cutting required at least as of yet. if you havent made your holes yet, scoot it forward so the angeled portion is closer to the center if the chassis.
#1454
i has thinking the TRG carbon print rear diffuser was painted!?!
but the picture show something else!?
hmm...
hmm...
#1455
that's because there is a clear one, and a carbon painted one.
