New TEAM WAVE racing brushless system
#466
Ran the RB30 in my world GT Sunday with 1S LiPo and 10.5 motor. Very impressed for the first run, it is very easy to set up and alter the settings.
Tried several gearings from 65mm up to 75mm roll out and basically confused myself as to weather the turbo was effective at the higher gear or not, or if I should go lower still???? Motor did not get hot at all so perhaps higher???
If anybody has any experience a bit of help would be much appreciated.
Looking forward to an update for 1S cutout
Paul
Paul
And a final note the updated software is smoother and punchier with a tad more top end and time shift 5 if you do not have would be good to look into!! hope this helps!!
#467
Thanks for the advice, will carry on with the experiments. Have not tried different drive profiles yet and don't realy understand them but I'm sure all will become clear.
If anyone is trying this speedo with 1S please share as I'm sure this speedo could be ideal in this form of racing.
#468
Like most companies they are always working on better software so sooner or later there will be a 1s update especially as 1s in becoming more common these days.
#469
Ahh that explains why I seemed to lack a bit of punch! I thought perhaps I was geared to high. Will go to max drive profile and try again.
Paul
Paul
#470
Hey guys,
I have an RB30 and 17.5t motor arriving tomorrow, and I need to get hold of some spurs/pinions fast for racing on Wednesday night.
What is a good ballpark for an FDR using the 17.5t in a touring car with turbo on a tight track?
I know there are alot of variables but I'm just looking for a ballpark for its debut.
Thanks,
Steve
Thanks,
Steve
#471
Hey guys,
Thanks,
Steve
Thanks,
Steve
#472
I am having some problems with my RB-50 to set it up before use, the green light flashes and the red one flashes. But the red light won't become stable??
is there some way to reset the esc? I am doing it corectly after the instructions
#473
As for the setup it is much the same as any other radio.
* Turn it on with the set but held down and wait for the green light.
* With throttle in neutral press set
* With throttle held full press set
* With throttle held on full brake press set
If it dosen't work right try reversing your throttle on the radio. You should also set you epa's to max before tuning. This will improve the reading of the throttle position by the speedo due to the increase in "resolution".
#474
Thanks Dragonfire...will give it a crack!
#475
Thanks for Dragonfire to answer most of the question
Team_Elli:
Release the button once you see green LED flashes and wait for solid RED LED. Do not press and hold until you see RED LED, that is profile setup mode.
Team_Elli:
#476
team wave will make a ESC for 1/12 on-road ?
#477
1/12 speedo RB-12 is on the way, stay tuned!
#478
Hi just wondering if anyone else has had problems using the RB50 with Futaba PCM...?? I cannot get the speedo to set or respond in any way...Finally used an old ppm reciever and everything set and worked fine. Love the turbo for spec racing, but wish it would work with PCM, less chance of interferance.
Thanks.
Thanks.
So why does this speedo did not connect correctly with Futaba PCM?
#479
I'm usually running my RB50 with TW Linear 3.5R 2S Lipo (factory default setting with Turbo On, my gearing 11.2)
but it seem i only get it running right just for 4 minutes then it cut off..
any setting advice will be appreciated..
Also what is the best setting for RB50 with 11.5R motor?
#480
I run mine on a 3PKS with either a 75Mhz module/rx combo or Spektrum Pro HRS combo. Both with HRS "ON". They work fine.
Cheers!!
