23T motor thread
#31
Originally posted by davioh
is it the blue one or the green one?
-Dave
#33
Re: Re: Re: some more 23T`s
I would run other motors...but most of the classes here in Japan are 23T..Mod isn`t that popular...plus..some of these new 23T`s go as fast as a new 10T Single flatliner I just bought.....
-Dave
-Dave
#34
Those Atlas ones will work just fine... I like the Hi Silver serated ones form Atlas the best
-Dave
-Dave
#35
Originally posted by dtm
You should get change out of HK$200.......
what kind of brushes does the SR use? i think i need a motor with laydown...cuz my mirage is really werid...has laydown AND stand up and i only hav standup brushes.
#36
what is the difference between the LR and SR?
#37
LR- Laydown RPM.....SR- Stand up RPM.....
#38
I did see those Hi silver ones...but was worried about comm wear...how often do you have to cut your comms with the Hi silvers??
-Dave
#39
told by ppl that the lower turn the motor is better/ faster... but fr this thread, seems 23T is very good/ fast motor...
anyway, is there anyway to know how many turns is the motor (if there is no label at the motor)?
is mod stand for modified?
#40
stock motor, 23 or 27 has lower RPM but high in torque.
You can take a look at the armature shaft (where u tighten your pinion). For some motors, the spec is written there. For some other motors, you can find it printed on the body of armature.
Yeap, mod means modified.
#41
about every 4-6 packs.... just a light skim...thats it also I don`t recommend going beyond 7.0mm on the new Yokomo 23T stocks..because you loose tons of torque
-Dave
-Dave
Thks...I'll give those Hi Silver brushes a try I think...
#42
You have taken a Yok to 7.0mm already!! it hasn't been out for that long!!!
-Dave
#43
#44
what would matter if the brushes are different?
-Dave
#45
so in general it's run time? would you recommend the rev or tourqe?
