23T motor thread >
23T motor thread
23T motor thread
Old 08-26-2004, 09:11 PM
  #781
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: Re: LR AND SR YOKOMO"S
Originally posted by tornado
Very recently in Japan there was a benchmark test on the new Sanyo 3600 and GP3300 in comparison. The results shows that the Sanyos perform better and higher voltage than the GPs at 20A discharge which is suitable for Stock Racing. GPs shows more performance at 30A discharge and this would appeal to boys running modified.
So guys...racing Stock...23T...Sanyo is ur cells I'm getting 2 myself. and stick to ur GPs if you're running modified.
Bryan
this might be why the RMP based 23T stocks do better since they don"t draw as much current/amps as the Torque based 23T's ...hence the reason why the GP cell is the one I will stick with ... Torque Baby!!
-Dave
JDM_DOHC_SiR is offline
Old 08-26-2004, 09:22 PM
  #782
tornado
Guest
Posts: n/a
Right on Dave !
Bryan
Old 09-14-2004, 04:49 AM
  #783
DJB
DJB's Avatar
Trader Rating: 17 (100%+)
hey guys
How often do you reckon I cut the comm on a tamiya super stock type RZ. i will be using a mixture of brushes (fantom 315s and tamiya std ones)??
Also what a good ratio on a tb evo 3 to run one of these motors (newbie to this class) Im running on a fairly short concrete pavlion.
thanks guys
DJB
DJB is offline
Old 09-29-2004, 02:22 AM
  #784
Talking Bump
Lots of good info here for the new guys that want info about 23T motors...
Happy Reading
-Dave
Old 09-29-2004, 02:25 AM
  #785
DJB
DJB's Avatar
hey guys i really need some advice here
whats the best rollout for a tamiya super stock type RZ on a tamiya tb evo 3?? ive never raced this class before and have no idea how to gear the things. are they like 27t stock motors?? or can you put a much bigger rollout in them.
any help plz
thanks guys
DJB is offline
Old 09-29-2004, 02:31 AM
  #786
tornado
Guest
Posts: n/a
Try the ratio within 5.8 to 6.0 I ran my older version RR using that ratio on a track with tight infield and a 100-120ft straight.
Bryan
Old 09-29-2004, 02:32 AM
  #787
any help plz
thanks guys
STart witha 6.2 final and go up or down depending on the track size..
-Dave
Old 09-29-2004, 02:35 AM
  #788
DJB
DJB's Avatar
Thanks so much guys. Another question if I have seperate brushes(315 fantoms) are they worth installing over the standard tamiya ones. is there a suitable difference?? Or stick with the standard setup??
DJB is offline
Old 09-29-2004, 02:37 AM
  #789
tornado
Guest
Posts: n/a
-Dave
6.2 hmmm...... yeah.
Bryan
Old 09-29-2004, 02:40 AM
  #790
tornado
Guest
Posts: n/a
dunno much 'bout fantom brushes as I'm using putnam green and blue combi or just team hurricane gold brushes with good results. I also use xenon's for bashing around.
Bryan
Old 09-29-2004, 02:41 AM
  #791
Get some Atlas SP sliver sprint brushes.. they are the absolute best for 99.9% of 23T motors
-Dave
Old 09-29-2004, 02:44 AM
  #792
tornado
Guest
Posts: n/a
Oh yeah ! Team Atlas too. Excellent stuff !!
Bryan
Old 10-04-2004, 02:55 AM
  #793
alana07's Avatar
Trader Rating: 53 (100%+)
Default Luna ATT 23T motor
hi all,
anyone out there have any experience with the Luna ATT 23t motor yet? does replacing the metal shims inside the motor with teflon shims make any significant differences? thanks....
alana07 is offline
Old 10-04-2004, 03:46 AM
  #794
Default Re: Luna ATT 23T motor
Originally posted by alana07
hi all,
Yep.. I have tried the ATT..that things got some Crazy torque!!! ..and I tend to gear in the it in the 5.2 range were I would normally gear a Yokomo ST in the 5.5 range... great motor... but as far as shimming it with teflon shims.. don`t waste your time... you will have better luck with getting more from the motor by messing with the brush hoods and getting the comm at it`s sweet spot.. 7.3mm
-Dave
Old 10-04-2004, 08:36 AM
  #795
Matt Howard's Avatar
Dave- I'll be making my maiden voyage into 23T racing at the end of the month at a Yokomo cup race here in S. Korea. My question is what is the fastest Yokomo 23T motor, from pics of the track it seems to be a good size and flowing so an RPM motor would probably be the ticket. I'll have to order it online so a good online shop would be nice too From what I've seen you guys gear these motors pretty high too, what kind of ratio should I start with?
Matt Howard is offline
