pro3
#916
You're right, there's lots of things HPI should have noticed about the car pretty early on - shame it's taken over a year for the parts people need to become available!
#917
Pro3
Yep---- I second the motion!!!!!!!!!
Maybe something still good will come out!!!!!!
So, hang on to your Pro3!!!!!!
It will still kick some but out there!!!!
Lem
Lem
#918
Regional Moderator
Re: Pro3
[QUOTE]Originally posted by lem2
[B]Yep---- I second the motion!!!!!!!!!
i hope its the proto there testing
#919
Pro3racing
Hi! Sir, sorry its been raining, no time to go out sa tracks.
Hope the body isstill available!!!!!!
Lem just text me
09178384618
Lem just text me
09178384618
#920
you should be able to run stick packs if you use slightly longer screws for the little winglets and they'll hold them in to some degree.
have a nice dya
sv
www.schumacher.clara.net
have a nice dya
sv
#921
Ok Pro 3 racers, the 3 is running well but I have to ask before I actually do this. I was told that you run the rear just a little stiffer then the front. The Pro 2 was the opposite in this regards. If anyone has some good input into the truth of this, fill me in.
#922
Are you going to race this weekend HPI 1?
#923
#924
I also run the same spring/oil combo on all 4 shocks, I am currently using the green linear springs with 50wt. And since I put the 4 degree blocks on my car turns great!! BTW I race on asphalt.
#925
Yodace, I will be out there. I don't have the horses to run with you all though or maybe it's the batteries. I'm good for the first 2 mins.
Thanks for the reply guys and much success with your HPI's. We are of few at the race tracks now-a-days. THat new prototype does look nice.
#927
HB Chassis
Yep, HB does not have slots but since the chassis is narrow your filament tape could go around it to prevent your stick packs from wobbling.
Well, I already graduated from stock packs---- and side by side does make it a lot easier with the slots and all.
#928
seeing as there are numerous different chassis out there like kai, penguin, prp, cross, hpi stock, HB, kai replica. whats your favorite one?
although i'm partial i still like the prp chassis, its rigid and can support the car w/ or w/o a top deck. but on carpet the top deck really helps!
#929
Chassis??
well I like the HB chassis, I am only using the Kai Replica.
SInce my Pro3 likes to sit low the narrow chassis prevents it from hitting the ground while cornering.
the HB and Kai i think could not function well without the upper deck, unlike the PRP but will still go with the HB with the PRP upper deck, a little flex i think is still needed by any chassis.
Lem
Manila, Philippines
Lem
Manila, Philippines
