CRC 1/10 Pan Car >
CRC 1/10 Pan Car
Like Tree3Likes
CRC 1/10 Pan Car
Old 01-07-2015, 08:16 PM
  #3946
Trader Rating: 16 (100%+)
Originally Posted by jetnjme
My wgt is the x10, I have the big losi TC style rear shock which is ok for running outdoor asphalt but should I get the smaller one used on the current cars for indoor carpet? Or is it preference?
Jaime,
I can let you use one of my CRC Encore shocks so you can decide for yourself. I did use the old Losi shock on my X-10 Pro when I ran a full sized 2S battery pack in my first WGT car's original configuration; but, the Encore works best for the standard 1S configuration used on the LE/SE setups.
Bill
Still Bill is offline
Old 01-07-2015, 08:35 PM
  #3947
wingracer's Avatar
Trader Rating: 24 (100%+)
I find the encore is smoother with less stiction so it's a good upgrade. Best upgrade you can do to an original X10 is the longer side links if you haven't already. Those two changes make it a beast of a car (in a good way).
wingracer is offline
Old 01-07-2015, 09:06 PM
  #3948
jetnjme's Avatar
Trader Rating: 19 (100%+)
Thank you Bill, that would be very nice.
Thank you wingracer, have but not installed or tried the long side links yet. I'll give them a try this sunday
jetnjme is offline
Old 01-08-2015, 08:36 AM
  #3949
YoDog's Avatar
Trader Rating: 28 (100%+)
The Encore shock is better period.
Carpet or pavement... Well worth the $15
YoDog is offline
Old 01-08-2015, 01:58 PM
  #3950
waltss2k's Avatar
Thanks for the pictures Bill
waltss2k is offline
Old 01-08-2015, 09:46 PM
  #3951
Originally Posted by Still Bill
Attached are a few pictures of my asphalt WGT 1S 13.5 Blinky SE. Same component layout applies to a 2S SE.
Come back to steering links straight? why?
regards
TyoBBS is offline
Old 01-08-2015, 11:35 PM
  #3952
regards
That is something that varies between my WGT cars. This car is currently straight. Other two are not.
And I mailed the two front end parts via mail to you today.
Bill
Old 01-09-2015, 05:44 AM
  #3953
rcgen's Avatar
I will be running the SE on carpet for the first time in our Spec 17.5GT class. For asphalt I went from a center red spring to a blue spring in the WGT class. Anyone running a 17.5motor and what center spring are you using?
rcgen is offline
Old 01-09-2015, 02:44 PM
  #3954
wingracer's Avatar
Almost always red. My WGT car often gets a copper (really turns hard then even in low grip) but spec car stays red. There is quite a variance in the spec bodies though so a different body might need something different.
Old 01-09-2015, 09:24 PM
  #3955
waltss2k's Avatar
I ran my SE for the second time tonight and won the A main for the second straight week.
waltss2k is offline
Old 01-10-2015, 06:43 AM
  #3956
l
Ok
PERFECT. I WILL TEST
Thanks and regards
TyoBBS is offline
Old 01-11-2015, 02:14 PM
  #3957
Trader Rating: 11 (100%+)
The club I belong to is adding a one day a month road course and we are going to have our own version of WGT (additional bodies), run on asphalt, 13.5 no timing with 1S. I have the LE and have the Hobbywing 1S ESC which works fine but they are always out of stock. A number of the members are asking what should I buy, so I was wondering what 1S ESC are being used and would a 2S ESC work if an external battery was used to power the receiver and servo. Thanks!
uscgretired is offline
Old 01-12-2015, 03:09 PM
  #3958
BadSign's Avatar
Trader Rating: 15 (100%+)
You can use a hobbywing justock without a booster. Also LRP's SXX line will work without boasters as well
BadSign is offline
Old 01-12-2015, 03:42 PM
  #3959
wingracer's Avatar
Viper vtx-1 and that cheap turnigy 1s speedo have built in boosters.
Tekins work perfectly with a booster or pack.
Old 01-12-2015, 07:21 PM
  #3960
rcgen's Avatar
I ran the SE for first time on carpet in our Spec175GT class with a HPI Corvette body. I ended up going with a white center spring and did not change any thing else. We ran on the same carpet that was used for the Worlds. It had a lot of grip and I was putting less sauce each time. We had twenty cars for this class and almost got to the podium for the B Main.
rcgen is offline
