CRC 1/10 Pan Car
#3286
30m run line sounds like a very small track. What are typical lap times?
Running the same motor as you are using on 2s LiPo, but on 1s, will halve the free-running RPM, since RPM is proportional to voltage.
#3287
Single cell 1/10th pan car gearing
The motor is a 3000kv, 13T Basic Sport system with a 35A ESC sold by "HobbyWing". When I use the 1cell pack I have to turn off the voltage protection in the ESC to get throttle.
Yes the track is small. You can view it on youTube at this link:
https://www.youtube.com/watch?v=7cVVsj_7GjM although we were running touring cars on that day. I was turning 5.5 sec laps using the exact same motor/esc that I plan to run in my pan car.
Thanks so much for your reply.
#3288
If we were to gear so the motor runs, on average, at its horsepower peak (which is half of the free-running RPM) we would be shooting for:
12600 RPM / 2 = 6300 RPM or
(6300 revs / minute) * ( 1 minute / 60 seconds) = 105 revs / second
Average speed on the track is 30 meters / 5.5 seconds = 5.45 m / sec
so we want a rollout of
(5.45 m / sec) * (sec / 105 rev) = 0.0519 m / rev
or, in mm, 51.9 mm / rev
Tire diameter = 2.43 inches or
(2.43 inches) * (25.4 mm / inch) = 61.7 mm
and the circumference is
3.14 X 61.7 mm = 193.7 mm
The gear ratio to achieve the desired rollout is
193.7 mm / 51.9 mm = 3.73
To be safe, I'd start out at about 4.5 and adjust from there depending on motor temperature.
A rear-drive pan car on caps with a 13T motor on that size track might be limited by wheel spin! You may find your lap times are better, and the car is easier to drive, by setting your throttle EPA to less than 100% (to limit torque). Then use a little more gear if necessary to get top end back.
#3289
I'd like to show up on Sunday and check out what kits are being run for WGT and type of esc's, motors and batteries being used.
What time would be good to show up without being in someone's way while asking questions or just looking?
i don't know of any wgt class running at WCRC.
i tried 1/12 and wgt cars at WCRC when they first opened, and found carpet tires to work best (black/yellow on 1/12 and greens on the wgt)
i gave up and ran rubber tire TC ( WCRC).
at TQ there is usually a good number of pan cars on Sunday, and certainly for the series races (next sunday june 9 will be a series race)
if you want see what the turn outs are like, Sean posts all the race results on his website, www.tqrcracing.com
#3290
Many Thanks
Okay, (3000 RPM/V) * (4.2V) = 12600 RPM no load.
Thanks so much for your help on this. I really appreciate the time you took to provide a great technical explanation that taught me how to make this calculation myself in the future.
Cancun Tom
#3292
January......
Howard,
Yes that would be great. We race outside all year long. January is cooler so it's much more comfortable. I can provide you with either a pan car and or a touring car, batteries, charger, tires, etc. I'll be the team owner and you can be the team driver. I'll send you my contact info via PM later today.
#3293
last sunday was a regular club race day and would have been a good time to drop by. series race sundays are pretty busy, there is a good turnout with maybe 15 heats to get thru. (track opens at 8, racing starts at 10, generally over by 5 and the track closes at 6)
#3294
CRC Pro Strut Camber Adjust???
Could someone give me a step by step description on how to set the camber on my CRC GenX 10 LE ?
Thanks in advance.
Thanks in advance.
#3295
camber settings are super easy on the CRC front end. It's a simple matter of turning the upper arms' pillow ball in (clockwise) to increase camber or to back the pillow ball out (counterclockwise) to decrease camber. Some wheels have holes or spoke spacings that will allow you to stick a long allen wrench in thru the wheel to make the camber adjustment while the wheels are on the car. But some other wheels don't have openings that line up with the allen in the pillow ball, so with those style wheels it can be necessary to remove the front wheel in order to access the allen recess in the end of the pillow ball. Most guys run their camber at around 1/2 to 1 degree (top of the front tire leaning slightly in towards the car's centerline). If you don't have a gage, one is not really necessary. The wear on the front tires will tell you what the car wants. Basically, the goal should be to adjust the camber settings so that the front tires wear flat accross and they don't cone, which should be a good setting. If the inner edge of the front tire tends to wear faster than the outer edge, then that wheel is leaned in too much (has too much camber). And if the outer edge becomes a smaller diameter than the inner edge.......then you need to add more camber. It's really very simple.
#3296
GOT IT!
VFFACTOR,
Thanks worked perfectly. Didn't see the access to the pillow ball.
#3298
Bill
#3299
How is your existing foam bumper currently connected to the graphite bumper? Besides the body posts, what screws are in place (if any)? And how far does the foam extend in front of the graphite bumper?
Bill
