Tamiya Ta06
#1397
thats cheating ¬_¬
currently a bit stuck on where you put the rear arms on....
this is not an easy build
#1398
Just added the carbon rear shock stay
#1399
Imstalled sway bars. I wonder if med front and rear is a good starting point. The way I remember it, if I stiffen the rear, I will have more front bite.
Regarding ifs, I noticed that the spring pre load has no effect or very effect on the front ride height. Is this right? The only way to change the height is to change the lengthy of the turnbukles.
For this reason I am considering replacing the ta06 blue alumn turnbuckles with some xray spring steel ones for durability. Any thoughts our advise ?
I still need some idras on where to mount the mylaps
#1402
man, i didn't realise how narrow this chassis was, compared to my previous one.....
#1405
Eagle racing kit installed! during this install, I remember how much I miss my "good" hex driver.
Best feature:
you unscrew 2 screws and the battery protector(that holds cell packs, accomodates tape AND this HUGE hardcase 2s lipo) slides out. Much easier than factory and (in my personal opinion) the rotating sidemount design...
Best feature:
#1406
No droop screws works awesome sway bars frt
No sway in rear
Traction is super planted even in hairpins
Love this chassis especially with tamiya carbon reinforced upgrades
I like to keep it Tamiya just in case I run tcs
No sway in rear
#1407
Tommy, are you running 17.5 or silver can, what gear ratio are you running? What spur gear do you do use?
thank you
thank you
#1408
3.47 fdr but it's at 160 degrees off the track
But I'm looking at using an 88 spur and 50 pinion for a 3.82 fdr next
The infield was not snappy enough
Gotta get some more spurs
Missed the race today it was so busy
#1409
finally going to be racing my TA06 tonight, can't freakin wait!
I do think i went a bit mental with the curly cables
