GM Brushless
#2416
Yea but we always run about 6 indoors and this guy wants some outdoor gearing. Obviously you should always test the gearing to check temps, especially with an X11 as the speedo can't shutdown for you cos of the lack of temp sensor.
So yea, considering I run about 6 indoors, I can't see why 5 would be a problem outdoors. Just be careful and check temps.
Remember that undergearing is going to make it overheat as well.....
#2417
Where can i get a 4.5 gm motor? The following site never has them in stock!!!
http://www.racing-cars.com/sp/catego...ss_Motors.html
#2418
http://demonpowerproducts.co.uk/prod...oducts_id=5339
#2419
Not strictly true. 7Delta is more like a 4.0 star - so more power and more heat than a 4.5. Also the power band is a bit different.
#2420
This 7t delta would be pretty similar in performance to a 4.5
#2421
The closest thing to a 4.5T is a 8t delta
#2422
Yes but there isn't any of those in stock on that site. So I chose the closest thing there.
#2423
true or false ?!
i came accross a funny product the other day. a CS-Rocket Competition Modified CX speedo. can someone clarify if the thing is the same as a GM 120 that i have in use? just want to know if one could transfer the newest software 13.1 to the CS speedo?! anyone?
#2424
Has anyone tried using the GM75 power cap on a GM120? The one from the 75 is a lot smaller so it would be nice if it worked.
I'm running 10.5 which is within the limits of the 75, so it seems like the power cap would be able to cope.
Ideally I'd just change to a 75 since its a lot smaller and lighter, but thats a bit of an expensive solution...
#2425
#2427
or use www.hobbydirect.de or just check prices and go to UK store and ask why it is so expensive
hehehe
btw deaemonproducts whatever still doesn;t work for Polish users, idiots ...
hehehe
#2428
Hi guys hoping some one can point me in the right direction. I have search through this thread but not found what i am after. How do i put my 2010 genius 90 esc into zero timing for old school racing. it has the lateset firmware installed.
Many thanks in advance Rob
#2429
If you haven't played around with any settings, then mode 2 would be 0 timing I believe.
#2430
Thanks Mattw will give it a try
