Serpent to 1/10th EP Touring Kit S400
#976
Anyone know who has S400 gear diffs in stock ???
#977
Does anybody have a carpet rubber/carpet set-up they can give me as a starting point for my S400? Also, Whats the best traction compound for rubber on carpet?
#978
I'm still running mine as per kit settings except but with 1mm kick up on the front. It's absolutely planted.
May I suggest you start there.
The other guy who has one changes setups as much as the UK weather system but he always comes back to the base settings.
Meanwhile I just amble along waiting for him to find something better and copy him when he does so.... hee hee.
Oh and he always TQ's, which is good but my; is it annoying.
#979
RUBBER CARPET SET UP
2 Hole pistons Front
4 hole Pistons rear
2 degree caster blocks
1mm shim on outer front ball stud ( camber link stock location)
5 mm ride height front and rear
Front one way 34 tooth gear ( overdrive )
1mm shim inside camber link rear and 2mm shim under outer on hub ( rear camber link all the way long.
2 degree tow block rear
1.6 front sway bar
1 mm shim under front lower a arm suspension holder
orange spring front
yellow spring rear
shock next to outer hole on front shock tower
shock next to outer hole on rear tower
front shock position outside on arm
rear shock position middle hole on the arm
2 degree inboard toe in the front
.75 degree toe out on each front wheel
sorex 24 tires premount
rear ball diff loose but no slip
mazda 6 body for extra rear bite or parma alfa to lossen the car up a little
all aluminum screws above chassis
need to add 90 grams if you use the aluminum screws
Front sway bar inside position on arm
not using rear sway bar
go to 4 degree blocks in the front and keep arms flat for more all around steering
Mazda body mounted 33.5mm from center post to windshield
3 mm droop all the way around on the blocks
4 mm of spacers in front of rear arms ( increase wheel base)
Paragon FX traction compound-tire warmers at 150 degree front 160 degree rear
CO27 30/102 4499 brushes
Trinity 4600 Enrich power
Sorry if I missed anything!! Let me know if I did!!
#980
Thanks for all the details.
#981
Melvin has a very good setup and the car is very fast.
I would like to say Happy Holidays to all, and a special thanks to all at Serpent USA. I look forward to representing the company in the new year.
#983
Thanks Tony I am looking forward to getting the car.
#984
hi guys, did u guys notice d front bulkhead seem ez to break when u hit something which nt reli tat hard..
i found out a solution on it, u ask those mechanic welding abit behind d bulkhead (d 1 tat attach to shock tower) skru hole abit to strenghten it..this can save ur couple of bucks to replace it.
#985
Hey guys..Racer Z setup looks really good. Felt even better for the 4-5 laps that I drove it. The car had a lot of corner speed but felt extremely stable. If I had better access to parts I would buy one ASAP. I would try his setup before trying anything else. He has put a lot of testing and tuning into that setup. Try it out.......
Matt Wells
Matt Wells
#987
Orion 3200 is what I run as well. I can't seem to find a hardcase lipo that will fit so I went withthe advice of someone on the forum and bought a maxxamps 5000 pack. It is a great pack and is only 18mm tall. If you find something that else that fits, please post.
PS. Has anybody got a 3600 Orion to fit yet?
#988
