Like Tree1Likes
Mugen MTX-4R
Old 12-02-2007, 08:52 PM
  #901
ShrekNZ's Avatar
Originally Posted by asw7576
I would stock these items before going to race :
Maybe one or two of :
2 rear belts, <--- preferably rubber type for all sort of belts
1 middle belt,
1 front belt,
1 set lower front and rear suspension arms,
2 set steering knuckles,
1 set rear upright,
1 set front CVD,
Bearings,
3 clutch shoes,
2 set of flywheel clutch weight
2 set of 2speed clutch,
1 set body post,
1 set of pivot ball plastic connectors <---- black plastic connectors that holds your steering linkage and suspension damper.
Spur gears,
Pinion gears,
2 one way 1st gear,
2 extra pipes
Shims for clutch gap
glow plugs
tires
Not too sure about the 2 rear belts as we tend to go through more side and front belts - the rubber ones do tend to last longer.
I would also add a pulley set (you can easily strip the rear side pulley and rear front pulley if you get a stone stuck)
Shock shafts and ends are also useful - the ends snap off in a hard crash.
ShrekNZ is offline
Old 12-02-2007, 10:40 PM
  #902
asw7576's Avatar
I don't know how many belts will be needed to suit anyone need.
I prepare 2 rear belts because one time a small stone slip into my rear bulkhead, and ruined my rear belt. This was happening when my car went out of course, into grass area.
asw7576 is offline
Old 12-03-2007, 02:05 AM
  #903
bobbyblaze's Avatar
cool thanks for the list......one more thing my hobby shop have parts out the whazoo for mtx3 like belts pulleys and a-arms etc can i use those on the 4r?
he like offering to me almost like free because no hardly race nitro
bobbyblaze is offline
Old 12-03-2007, 03:12 AM
  #904
Seisick's Avatar
Originally Posted by insanewulf
That is the same one that came with my R kit for the rear. Thanks Again
you can download the manual from mugenseiki.com if in doubt
rear cup is t0261
Seisick is offline
Old 12-03-2007, 11:12 AM
  #905
Casey Belarde's Avatar
I have been running a oneway and a rear spool hear in spokane,wa our track is about 170x90 med grip car seems pretty hooked up
Casey Belarde is offline
Old 12-03-2007, 05:19 PM
  #906
Trader Rating: 61 (100%+)
rear cup is t0261
You are right. I misread the manual. I could have answered my own question if I would have read the manual thoroughly. Thanks again.
insanewulf is offline
Old 12-03-2007, 06:34 PM
  #907
lil-bump's Avatar
Trader Rating: 89 (100%+)
Hello gentlemen,
What after market company sells the light weight front lay shaft? Any part numbers would be appreciated. Any one know if Kawahara offers one for the MTX-4?
lil-bump is offline
Old 12-04-2007, 02:39 AM
  #908
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by lil-bump
Hello gentlemen,
I think I saw a knack titanium one the other day on rcmodel. Otherwise sato seiki make one, from what i hear they're quality isn't too crash hot tho
CraigM is offline
Old 12-04-2007, 04:46 AM
  #909
only use the lightweight tinanium or alloy variety on the front shaft.
never use titanium shafts for the two speed. only use hollowed steel. i had a hollowed steel shaft and it eventually wore out. get yourself 2 or 3 as spares as they do wear out, and this causes the gears to strip. i'd say change every 6 months if you race once a fortnight.
TomB is offline
Old 12-04-2007, 08:17 AM
  #910
Seisick's Avatar
yes, i have the sato seiki for a year and it shows wear, wish if mugen makes a hollow one, the sato alum shaft is you never disassemble your car it is ok but if you do it 3 or 4 times, it will show sings of wear where the setscrew rests and eventually it will get loose.
Seisick is offline
Old 12-04-2007, 10:09 AM
  #911
R/C Tech Elite Member
JayL's Avatar
MSR has a ti front shaft, nitrohouse.com has it
JayL is offline
Old 12-04-2007, 03:14 PM
  #912
lil-bump's Avatar
Thanks for the info,
I just want a light weight front lay shaft. I have a lighten steel shaft in the rear (not hollow, it just has some of the material removed but it's solid). I forgot about nitro house I will check with them.
Again gentleman, thanks for the info!!!
lil-bump is offline
Old 12-04-2007, 04:48 PM
  #913
SOLOARTIST 702's Avatar
Default hmm
rear shaft is what k-factory
SOLOARTIST 702 is offline
Old 12-04-2007, 06:42 PM
  #914
lil-bump's Avatar
I'm not sure what brand it is. I picked it up off a fellow on the for sale boards.
The shaft is steel but it's semi hollow its hollow about 3/4 of an inch on both sides and solid in the middle. and it has been lighten every where except where the bearings ride. I'll search boards and see which one it is.
lil-bump is offline
Old 12-04-2007, 08:11 PM
  #915
lil-bump's Avatar
I did a search and I believe it is a K-factory shaft. Holds up well, no signs of wear
lil-bump is offline
