XRAY XB8EC THREAD >
XRAY XB8EC THREAD
XRAY XB8EC THREAD
Old 05-24-2007, 11:03 AM
  #76
PTP Racing's Avatar
I got to race mine for the first time this past weekend and really like it.
I ran into only 2 minor things during the build the bearings did not fit tightly into the bulkhead where the pinion goes through and I wasnt getting full droop in the front. But I fixed both of those issues now.
I also drilled the shock piston out to make them 4 holes which seems to give a fantastic feeling shock.
I did really well in qualifying this past weekend but ran into trouble in the main when my relatively new ceramic clutch bearings went bad and I stripped the stock plastic steering servo horn. But both of those happened after getting at least 2 full flawless hours of run time on the car.
PTP Racing is offline
Old 05-24-2007, 08:09 PM
  #77
Has anyone tried the HT Batteries Lipo for the XB8 in this? I would assume it would fit right? Has much changed with the battery box since the XB8?
*Topher* is offline
Old 05-25-2007, 02:04 PM
  #78
PTP Racing's Avatar
The battery box hasnt changed at all. But I personally dont want to alter the weight balance by running a lighter battery so I am using a normal 1400mah nimh pack in mine.
Old 05-26-2007, 02:09 PM
  #79
Trader Rating: 26 (100%+)
anyone know when the xt8 will be released
eddie10 is offline
Old 05-27-2007, 08:59 AM
  #80
Trader Rating: 42 (100%+)
ive heard around mid june or so
heres my ec set-up this one works geat mabe just spring changes
http://forum.teamxray.com/xform/inde...95&setup=xb8ec
KEITH is offline
Old 08-01-2007, 07:06 PM
  #81
Trader Rating: 14 (100%+)
I have an original XB8 that I picked up from a friend.
Does anyone know if the TQ -> EC conversion set will work on it?
Thanks.
Slippery Dan is offline
Old 08-01-2007, 07:10 PM
  #82
pink_sleeve's Avatar
Trader Rating: 220 (100%+)
why is this under the electric forum
pink_sleeve is offline
Old 08-01-2007, 07:28 PM
  #83
AndyMoore's Avatar
Trader Rating: 64 (100%+)
It was an older thread before they changed the format of the forum. I assume they went only through the first couple of pages of threads in "offroad".
AndyMoore is offline
