Xray NT1
#4411
Hi guys I am having an issue getting my camber to set as I would like, I have rebuilt the car and the rear has all new parts. I placed the car at stock settings as per build but the problem comes when I try setting the Rear Camber I have placed the camber link on the #4 hole and I am trying to sent the camber using the Hudy setup to 3 degrees Right and 4degrees on the Left but after fully adjusting the camber turnbuckles I am only able to get 2degrees on both sides.
What could be causing this limitation or is it possible to get 3 degrees camber when the links are in the #4 hole?
What is the track width of the rear of the car? If it is too narrow, that could cause this to happen and you could use the -0.75 optional hex's to help narrow the rear and screw the pivot balls out to help get that camber setting you want.
How much rear toe are you running? This too could cause you from getting to that setting you are looking for if you are using too much rear toe.
Looking at my car in front of me, I am using the #4 hole too, and I have a 3.75 on the left and 3 on the right. I am using 2deg rear toe and a track width of 198 with the -0.75 hex's.
If you still cannot get the setting you desire, you might have to grind off 1mm on each end of the camber turn-buckle so that you can make the needed adjustment.
#4412
miss post
#4413
SURIKARN in ASIA XRAY CUP first round TQ.
#4414
#4415
#4416
#4417
#4418
RC market : Where can I see all drivers ranking position ?
#4419
#4420
Yes !
#4421
#4422
#4423
#4424
#4425
