Yokomo GT-4??? >
Yokomo GT-4???
Yokomo GT-4???
Old 11-10-2001, 10:54 PM
  #46
Regional Moderator
disaster999's Avatar
hey...im just wondering, i got the GT4R kit, and the foam front and rear tires are different diameter, it is ok if i put regular rubber tires on the car? or do i have to change the gear ratio?
disaster999 is offline
Old 11-11-2001, 01:53 AM
  #47
Manticore's Avatar
for foam tire, you need a little bit small diameter in the front. usually you need 2mm smaller. it applies to other GPs.
when you go back to rubber tire, you cannot change tire diameter but to adjust ride high.
Manticore is offline
Old 11-11-2001, 02:11 AM
  #48
Regional Moderator
so...theres nothing wrong if changing back to rubber tires then...right? like...the wheels would all turn at the same time at the same speed...??
Old 11-11-2001, 06:10 AM
  #49
Manticore's Avatar
yes
Old 11-11-2001, 09:19 AM
  #50
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Edited
Dan is offline
Old 11-11-2001, 09:49 AM
  #51
Hi. I don't race a Yoke but I have a Mugen and saw one of the forums above regarding how some people use Serpent of Mugen 2-speed clutches. Kawahara makes 2-speed clutches for the MTX-2 for around $65.00. Much cheaper than the stock Serpent or Mugen ones I think.
Dunno if that helps
ryan is offline
Old 11-11-2001, 06:26 PM
  #52
che
che's Avatar
Default GT4R?
Is there any places that have the GT4R in stock?
And how much are the selling for?
Che
che is offline
Old 11-12-2001, 06:26 PM
  #53
To fix the pin wearing problem, simply buy a titanium, or steel drill bit, of the same size or larger than the hole in the hub, and drill it in, and cut it off....best, and simplest solution i have found. However, i have noticed that the newer GT-4R and the latest Gen. GT-4s have been comign with stronger pins.
RyanS is offline
Old 11-12-2001, 07:20 PM
  #54
Regional Moderator
Originally posted by YANMAN
If you get the new Yokomo GT-4R, you will not need to add another thing to your car. We just had the Roar Region 9 Champ. race this past weekend. 1st through 5th were all Yokomo's (me being 4th) I won the B main which was 20 min and bumped up to the A-main which was 30 min. I did not break a single part all weekend and I was running the stock clutch, gears and 2-speed. As a matter of fact all 5 of the top guys were running the stock 2-speed, clutch and gears. YOU DO NOT NEED ALL THAT EXTRA CRAP!!! I have had every Nitro TC on the market, except for the Kyosho, and the Yokomo is the best car I have driven.
did you race the car box stock or with some hop ups....like grahpite radio plate...threaded shocks....full universals...??
do you have mtx2 or v-one-r or impluse?
how do you think the GT4R compare to those?
Old 11-12-2001, 07:31 PM
  #55
YANMAN's Avatar
Trader Rating: 41 (100%+)
Yes, I did run the car box stock. The GT-4R comes with aluminum side radio posts, front one-way, solid rear axel, new lower profile radio plate, threaded shock bodies, and aluminum side front over-drive gears. I have added the rear side aluminum braces but that is it. I paid $360.00 USD from www.Speedtechrc.com.
No I do not own any other car because the Yokomo is the car to have. I owned a Mugen and Serpent but no Kyosho. From what I saw at the Roar Nationals in Houston, Texas the yokomo is the best car. The Mugen would be next then the Kyosho.
The GT-4R also comes with new front universals. So like I said you do not need to do anything to this car unless you want to.
YANMAN is offline
Old 11-12-2001, 07:47 PM
  #56
Red face
Yea yantes!
You are the man, even though i own you on the track!
LOL!!!!!
Just kidding man!
RyanS is offline
Old 11-18-2001, 06:28 PM
  #57
Would anyone know how much the GT4R weighs?
vapourtrail is offline
Old 11-21-2001, 02:19 AM
  #58
Is the locked rear made of steel or aluminum?
Old 11-26-2001, 09:25 PM
  #59
Steel!
Racer 1 is offline
Old 11-26-2001, 09:46 PM
  #60
Talking
Heres my 2 cents on the GT4W
Pro's
1. Very well thought out chassis etc.
2. Every part fits well after trimming some parts.
3. Handling is awesome and parts are tough.
4. Nice upgrades available from YOKOMO at a resonable price.
5. up and down stops all 4 corners
Con's
1. Bearings are trash
2. Stock tires are trash.
3. 1st and 2nd designed tanks trash
4. leaky diffs.
5. instructions could have given more info for setting up the sedan.
6. No side belt tensioner a must have item.
Racer 1 is offline
