CRC's New Generation-X.... Your Thoughts? >
Old 01-15-2007, 08:14 AM
  #631
dr_hfuhuhurr's Avatar
Trader Rating: 95 (100%+)
Has anyone put any thought into swapping the 1 piece links out for 3 piece links? When I had my 3.2R I swapped it out to the 3 piece links to keep the slop out. Anyone try this or have any ideas on how best to do it?
dr_hfuhuhurr is offline
Old 01-15-2007, 10:39 AM
  #632
dr_hfuhuhurr, I do like that idea, Let me know what parts you use if you do it.
The only problem I see would be getting the the correct size without having the pod cocked in any way.
All for now
Jack
jackh is offline
Old 01-15-2007, 11:33 AM
  #633
fraz's Avatar
Originally Posted by wallyedmonds
...but i do wish the axle was still small...
I am glad they designed the car with bigger axles. I can't recall how many times I've been bit by slightly bent 1/8" axles. It didn't seem to matter if they were steel or Ti, they bend pretty easy. These new 3/16" axles don't look like they'll bend at all.
fraz is offline
Old 01-15-2007, 12:39 PM
  #634
Scott's bent.
Tony Vega is offline
Old 01-15-2007, 02:54 PM
  #635
I've seen two front arms break, and they both fractured at the point where the screw holds the arm to the chassis. In both cases the main 8-32 screws were too short to go all the way through the arm (which happens with the stock screws and bigger tires). I've been running longer screws that go all the way through the holes in the arm (plus smaller tires which lowers the arm) and haven't had a problem yet... Is this where everyone else is breaking arms?
James
Yankey is offline
Old 01-15-2007, 02:59 PM
  #636
stiltskin's Avatar
Trader Rating: 103 (100%+)
All three that I broke, snapped right at the front screw. Almost identical breaks.
stiltskin is offline
Old 01-15-2007, 07:38 PM
  #637
B&B Racing's Avatar
Was wondering if anyone has installed the Gen-X frontend on one of the older cars? If so, how did it change the steering?
djb
B&B Racing is offline
Old 01-16-2007, 03:50 PM
  #638
wallyedmonds's Avatar
James
i did not break mine like that,it broke buy the lower ball.
wallyedmonds is offline
Old 01-16-2007, 03:52 PM
  #639
this is true for that,but the smaller bearings work better,and have less slop in them.
Old 01-16-2007, 03:58 PM
  #640
try using the rpm center links,part # 70892
Old 01-16-2007, 04:12 PM
  #641
Originally Posted by Trips
The o-ring lets the battery jump up and hit the shock, then it pops the battery back into place. I was stumped too until someone told me...
then how did i do this in my L4 last year,i think its inertia,like when you hit the front but your rear axle breaks.
Old 01-17-2007, 01:13 PM
  #642
Default Broken A arms
I broke 2 lower A Arms Sunday, BUT if I didn't hit the boards and if I didn't put my car on the track where it shouldn't have been I would have never broke them. + I was using Associated front end parts, so I can't say anything about the GenX front end. I have one but I haven't installed it yet because I am afraid I will break it and I don't have any extra parts. , I also had to get bearings for it which was another reason I haven't install it yet. ( Thanks Greg ).
Jack
jackh is offline
Old 01-18-2007, 12:10 PM
  #643
Just installed my LRP Sphere. The connectors are from Integy 3.5mm Euro Connectors. I think it'll work, can't wait to try it out Sunday.
Also...you can see the black aluminum on there as well.
Attached Thumbnails CRC's New Generation-X.... Your Thoughts?-genx-001.jpg   CRC's New Generation-X.... Your Thoughts?-genx-002.jpg   CRC's New Generation-X.... Your Thoughts?-genx-003.jpg
Old 01-18-2007, 12:20 PM
  #644
JFCJ's Avatar
Trader Rating: 31 (100%+)
Blake,
Very nice and clean... I may have to look into going with some plugs...
Have you tested the side-to-side balance?
James
JFCJ is offline
Old 01-18-2007, 12:23 PM
  #645
Thanks...the right side is a bit light but not much at all. I'll get that fixed tonight or tomorrow.
