Xray T2'007
#2101
Hi all
I just got a 007 and am trying to install the 2 belts for it. I have the diffs and the belts in place and when I rotate the spur gear, If feels like the larger belt is catching on something because there is resistance at a point. Has anyone had this issue and know some ways to solve it?
Also, how important is it to clean and re-oil the bearings before you run the car for the first time? I think those are blue rubber sealed and they are hard to get open. I have no problem with the diffs and spur gear being free and stuff so I was wondering if it was a big deal.
Thanks for the help
Thanks for the help
#2102
Originally Posted by Ridge_Racer
Hi all
Thanks for the help
Thanks for the help
As for the bearings, it is best to oil them before the first time you use them.
#2104
Originally Posted by A. Rhodes
Check the screws on the spur gear, they may be hitting the upper deck.
Thanks again
#2106
Hi again.
I'm getting a little ahead of myself with this one but I was wondering where to start for gearing. I was gearing my TC3 at 7.5 FDR. With the XRay's light chassis I was thinking of gearing up if using a stock or C027 motor.
#2108
no, the xray uprights have a burshing that hold the bearing so they are smaller. the team tamale ones use the stock bearing
#2110
What's the best fan system to use these days? Are fan necessary? I've noticed some criticism on the MuchMore fans.
AWhich size spur will give the best range of gearing? Can the car resist small debris well enough to use 64 pitch on asphalt?
Also what arrangements of shims, spacers, hubs etc.. are a good starting point for setup?
#2112
Check out www.teamxray.com Click on >>>SET-UP SHEETS
-there's a bunch of good info on the XRAY site.
See you soon!
#2113
Originally Posted by ShaunMac
Did you get a new 007 Dane? You going to race asphalt in Trenton?
See you soon!
See you soon!
Nah - bought a T2R. Have you received the cyclone yet?
Thanks man
#2114
Ok, I checked the car over to see where the belt was hanging up at. It looks like the larger forward belt will, at a point, start rubbing on the side of my front one way. That is, the belt would move to the side, start rubbing and then move back toward center. Is their some alignment problem somewhere? I did notice that, on the spur gear, one of those composite hubs that hold the bearings was installed backwards. I fixed that and the rubbing continues. I will check into your other suggestions when I get home today.
any clues (thanks for the help so far)
